Re: Sreet/strip guys...mechanical fuel pump??
[Re: cudadoug]
#1543414
12/03/13 11:55 PM
12/03/13 11:55 PM
Posts: 1,267 North, Alabama
D-50
North, Alabama
I am running a Carter mech. strip pump on my pump gas small block, 3/8 line and autozone fuel filter.I drove 40 miles round trip to the last race and ran my new best of 6.29,1.33 60ft.@ 108 in the 1/8 so far. I hope to have the fuel system upgraded by spring so I can put my 1050 carb. on it.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
[Re: D-50]
#1543415
12/04/13 02:42 AM
12/04/13 02:42 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
I just use the Holley black pump and the stock tank. I put a 3/8 sending unit in my stock tank and run 3/8 line in the stock location. Pump and filter mounts back by the tank. And I use a pump block off plate where the mech pump was. Works fine for 10.70's and still pulling good thru the traps. Ron
[Re: StealthWedge67]
#1543417
12/04/13 05:26 AM
12/04/13 05:26 AM
Posts: 214 Hamburg / Germany
Den300
Hamburg / Germany
Rick Eherenberg sells one for a very good price at the bay. 3/8" all the way. built in pressure regulator. he claims it is good for 700hp. ordered one but it is not delivered and installed right now.
Hamburg/Germany
69 Chrysler 300 446cui Dual Quad 12.64 @ 110.7
[Re: Mr.Yuck]
#1543420
12/04/13 11:31 AM
12/04/13 11:31 AM
what is the application? Carter and Holley make good street pumps, I ran an Autozone replacement on my old 440-6 (11:1 528 solid cam, 1.5 rollers, headers, 3800 stall, 3.91's). Worked just fine. It all depends on how much gas you need.
Like the title says...."street/strip"
[Re: cudadoug]
#1543421
12/04/13 11:35 AM
12/04/13 11:35 AM
Posts: 290 Cincinnati, Ohio
d7cook
Cincinnati, Ohio
I've ran a Carter strip pump into the 10's with a tunnel ram in the past. Right now I'm using a Clay Smith pump and love it. It needs a regulator, it needs to be clearanced at the block but it pumps a lot of gas.
1967 Coronet, 1989 Daytona tube chassis.
Former cars, 66 Charger, 67 R/T, 69 Coronet, 67 Dart GT.
-Banned for life from V8Buick.com-
[Re: ]
#1543424
12/04/13 01:52 PM
12/04/13 01:52 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
yeah like I said and? I've seen guys w/ 12.20 "strip cars" and 10 second "street" cars. In any even the carter and holley pumps will get a BB car well into the 11's w/o an issue, even w/ tiny 5/16 line.
#1543425
12/04/13 01:53 PM
12/04/13 01:53 PM
Posts: 5,080 organ
maximum entropy
organ
carter strip pump with regulator, 10.60. still shows 6psi at the stripe. it gets driven a couple thousand miles a year, is about 15 years old, and has been stone wall reliable (as opposed to numerous failed attempts at electric pumps).
[Re: cudaman1969]
#1543428
12/04/13 04:35 PM
12/04/13 04:35 PM
Posts: 9,876 Weddington, N.C.
Streetwize
Weddington, N.C.
Has anybody ever run a small parallel electric pump (like the Mr. Gasket 12S ~ 35gph) as a booster? They also help a ton with hot starts to refill the bowls on a mechanical. It was a fairly common hop-up for running 50-100 shots in the early nitrous days when things weren't all high-dollar sophisticated like today. I used to have one of those old "Chinka-Chinka" Dupree's that I used to cut on with my N20 "armed" switch You can also use it as a 'jockey' (for you firemen and fire protection guys out there) pump with a return loop. I used to put it on a 3 position switch (off/jog( i.e. momentary)/run). BTW, they also make for a nice inexpensive "limp-in" system if you ever lose your high dollar pump on the street or at the track @cudaman1969....that's one of the (sometimes forgotten) practical advantages of a rotary vane pump (as opposed to the more modern georotor)....you can series it upstream of your mechanical and still pull the gas through it without the electric pump running.
[Re: Mr.Yuck]
#1543430
12/04/13 07:27 PM
12/04/13 07:27 PM
Posts: 498 El Dorado Ca
65signet
El Dorado Ca
Carter Pump -6 line 11.20s 360 with an 850 carb
1965 Plymouth Barracuda 273 M/SA 1970 Plymouth Duster 360/904 10.60s with J heads
[Re: 65signet]
#1543431
12/04/13 09:36 PM
12/04/13 09:36 PM
Posts: 3,245 Between a rock & a hard place
cudadoug
Application is a warmed up 408 or 360 (haven't 100% decided yet) in a STREET/strip 69 Dart. Goal: No quicker than 11.50's in 100% street trim as it doesn't have (nor will get) a roll bar.
I have a new Holley black pump and the AN hose and fittings in stock, but not sure I want to mess with all of that. AND it would add to the "sleeper-ness" if it was a mech pump and OEM 3/8 lines.
[Re: cudadoug]
#1543432
12/05/13 09:16 AM
12/05/13 09:16 AM
Mr.Yuck
Brookeville, Md
you could probably get away with either the carter or holley mech pump and your stock 5/16 line, however it won't hurt to upgrade to 3/8, just remember to get a 3/8 pick-up as well.
