Re: video of 5.81 pass
[Re: 440W8 Duster]
#1542943
12/07/13 05:40 PM
12/07/13 05:40 PM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
It's got a baby cam in it. I think it needs more cam. What is the altitude you race at?
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: 440W8 Duster]
#1542952
12/07/13 10:01 PM
12/07/13 10:01 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
600 ft DA is nothing to complain about.
Most sea level tracks I run in the Spring and Fall are doing well to be 600 ft. after 12P.
Leon
[Re: 440W8 Duster]
#1542957
12/09/13 02:04 AM
12/09/13 02:04 AM
1967dartgt
Hilltown Pa
I think I have a bigger one or real close I will have to check I think my lobe lift is 440 with a 1.75 rocker. That's with 422 cubes and only 12.0 compression .
[Re: 1967dartgt]
#1542958
12/09/13 11:47 AM
12/09/13 11:47 AM
Posts: 1,499 San Antonio,TX
440W8 Duster
San Antonio,TX
Brad I will tighten up the lash when I dyno it to see if it wants more cam.
70 Duster W8 motor. 1.29 60ft 5.79 1/8 at 120 mph glide with 1.80 gear @3170 lbs.
[Re: 1967dartgt]
#1542960
12/09/13 12:53 PM
12/09/13 12:53 PM
440W8 Duster
San Antonio,TX
hopefully this month but they are pretty busy so he says. As long as I get it done bye Feb. If I cant I might go to wright Mn. to dyno at Line Performance.
