Page 2 of 3 1 2 3
Re: video of 5.81 pass [Re: d4rt] #1542942
12/07/13 05:25 PM
12/07/13 05:25 PM
San Antonio,TX
440W8 Duster Offline OP
San Antonio,TX
70 Duster W8 motor.
1.29 60ft 5.79 1/8 at 120 mph
glide with 1.80 gear
@3170 lbs.
Re: video of 5.81 pass [Re: 440W8 Duster] #1542943
12/07/13 05:40 PM
12/07/13 05:40 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
It's got a baby cam in it. I think it needs more cam. What is the altitude you race at?
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: video of 5.81 pass [Re: 1967dartgt] #1542944
12/07/13 05:48 PM
12/07/13 05:48 PM
San Antonio,TX
San Antonio,TX
corrected altitude is about 4000ft in Minot,Nd where I race the last 3 years.
In the video it was 600ft that day and 39 degrees with a 20-25 mile an hour head wind coming in at about 1 o'clock.
70 Duster W8 motor.
@3170 lbs.
Re: video of 5.81 pass [Re: 440W8 Duster] #1542945
12/07/13 06:12 PM
12/07/13 06:12 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
I wonder what it would run at sea level?
Re: video of 5.81 pass [Re: 440W8 Duster] #1542946
12/07/13 06:32 PM
12/07/13 06:32 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Looks good... is that on race fuel or E-85
Re: video of 5.81 pass [Re: 1967dartgt] #1542947
12/07/13 06:34 PM
12/07/13 06:34 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
what cam and lifters and carb are you running
Re: video of 5.81 pass [Re: 1967dartgt] #1542948
12/07/13 07:27 PM
12/07/13 07:27 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
You guys that race at sea level are spoiled.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: video of 5.81 pass [Re: MR_P_BODY] #1542949
12/07/13 07:57 PM
12/07/13 07:57 PM
San Antonio,TX
San Antonio,TX
No its not Mike I bought a Bob Book carb and running on C12.I think I need C14.
70 Duster W8 motor.
@3170 lbs.
Re: video of 5.81 pass [Re: WHITEDART] #1542950
12/07/13 08:00 PM
12/07/13 08:00 PM
San Antonio,TX
San Antonio,TX
Cam was spec by Brett Miller and lifters are Crane Ultra Pro.
70 Duster W8 motor.
@3170 lbs.
Re: video of 5.81 pass [Re: pittsburghracer] #1542951
12/07/13 08:01 PM
12/07/13 08:01 PM
San Antonio,TX
San Antonio,TX
I don't know but I wish I was close to sea level!!
70 Duster W8 motor.
@3170 lbs.
Re: video of 5.81 pass [Re: 440W8 Duster] #1542952
12/07/13 10:01 PM
12/07/13 10:01 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
600 ft DA is nothing to complain about.
Most sea level tracks I run in the Spring and Fall are doing well to be 600 ft. after 12P.
Leon
Re: video of 5.81 pass [Re: 440W8 Duster] #1542953
12/07/13 10:02 PM
12/07/13 10:02 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
I've been to Fargo in the fall when the DA is around 200 and the temp was 60-65. You'll hit it one day! Still hoping to make it to Oahe next spring or fall....
Re: video of 5.81 pass [Re: J_BODY] #1542954
12/08/13 02:21 AM
12/08/13 02:21 AM
PA
W5DART66 Offline
W5DART66  Offline
PA
Jesse post cam info if you would like.
I don't keep record of cam numbers they are customers when I am done.
Re: video of 5.81 pass [Re: 440W8 Duster] #1542955
12/08/13 12:46 PM
12/08/13 12:46 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
That ALL you got???
hope not I bet it ends up some where in the 5.30 range
I don't think it will run that fast but will be happy with a 5.60's.
that is a very nice car.. I think 5.60 will come really easy. mph shows good hp for 3000+lb car with a two speed.it is hard to find the right converter. I no a few guys that have tried 4or5 different converters before they find the right one. I bet a protrans 904 will pick you up a tenth or two easy
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: video of 5.81 pass [Re: 1967dartgt] #1542956
12/08/13 02:25 PM
12/08/13 02:25 PM
San Antonio,TX
San Antonio,TX
70 Duster W8 motor.
@3170 lbs.
Re: video of 5.81 pass [Re: 440W8 Duster] #1542957
12/09/13 02:04 AM
12/09/13 02:04 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
I think I have a bigger one or real close I will have to check I think my lobe lift is 440 with a 1.75 rocker. That's with 422 cubes and only 12.0 compression .
Re: video of 5.81 pass [Re: 1967dartgt] #1542958
12/09/13 11:47 AM
12/09/13 11:47 AM
San Antonio,TX
San Antonio,TX
Brad I will tighten up the lash when I dyno it to see if it wants more cam.
70 Duster W8 motor.
@3170 lbs.
Re: video of 5.81 pass [Re: 440W8 Duster] #1542959
12/09/13 12:35 PM
12/09/13 12:35 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
When you going to dyno it?
Re: video of 5.81 pass [Re: 1967dartgt] #1542960
12/09/13 12:53 PM
12/09/13 12:53 PM
San Antonio,TX
San Antonio,TX
hopefully this month but they are pretty busy so he says. As long as I get it done bye Feb. If I cant I might go to wright Mn. to dyno at Line Performance.
70 Duster W8 motor.
@3170 lbs.
Re: video of 5.81 pass [Re: 440W8 Duster] #1542961
12/09/13 09:37 PM
12/09/13 09:37 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
keep us posted sound like it is coming around for you
Page 2 of 3 1 2 3
