video of 5.81 pass(New Video added)
#1542922
12/02/13 10:55 PM
12/02/13 10:55 PM
Posts: 1,499 San Antonio,TX
440W8 Duster
San Antonio,TX
70 Duster W8 motor. 1.29 60ft 5.79 1/8 at 120 mph glide with 1.80 gear @3170 lbs.
Re: video of 5.81 pass
[Re: Plumb Wired]
#1542928
12/03/13 01:29 PM
12/03/13 01:29 PM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
Nice pass, it's starting to come around for a na small block.
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: 440W8 Duster]
#1542933
12/03/13 11:00 PM
12/03/13 11:00 PM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
nice combo what dose the car weight.. im doing a motor that is very close to yours . brett did his magic on my w8 as well. did you get any dyno numbers..
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
[Re: WHITEDART]
#1542937
12/05/13 08:55 PM
12/05/13 08:55 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
Those numbers are almost identical to my R5P7 440. I can almost guess what the HP and torque numbers are.
I am curious to what the cam specs are. Wonder how close they are to my R5P7 engine cam specs.
My little 421W8 only left that hard with an unknown coverter and blew up thanks to some interference with pistons and valves. That's another story. I had to give the converter up and never had that luck with any I had built. The engine was pretty much a gutless wonder that ran like stink on the big end.
I will gladly share my cam numbers on an open forum but, can understand if you want to keep those to yourself.
Leon
[Re: 440W8 Duster]
#1542940
12/05/13 11:03 PM
12/05/13 11:03 PM
440W8 Duster
San Antonio,TX
I Will have to ask Brett about it?
