SB Mickey Thompson Valve Cover Grommets/Breather #1542903
12/02/13 08:33 PM
12/02/13 08:33 PM
Indy
moparman89 Offline OP
Indy
I'm in need of a source for grommets and breathers for these valve covers. They have 1.50" holes and I cant seem to find anything that'll fit.
School of Automotive Machinists Racing
Re: SB Mickey Thompson Valve Cover Grommets/Breather [Re: moparman89] #1542904
12/02/13 09:14 PM
12/02/13 09:14 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
All the online folks have them, checkout this page.
web page
I bet almost all decent auto parts houses can get you a grommet kit for a Mopar.
Like you said, you need a 1.5" hole for the breather and a 1.00" hole for the PCV valve.
Re: SB Mickey Thompson Valve Cover Grommets/Breather [Re: Challenger 1] #1542905
12/02/13 09:54 PM
12/02/13 09:54 PM
Indy
Indy
Yeah Google is great. 1.5 is not a common size, click on some of the links you posted, most are 1.22OD. There is one mopar "kit" I found which includes three plugs, only one of which will fit.
Re: SB Mickey Thompson Valve Cover Grommets/Breather [Re: moparman89] #1542906
12/02/13 10:39 PM
12/02/13 10:39 PM
Cincinnati, Ohio
Cincinnati, Ohio
I still think they will fill. I just checked a MT cover I have here and the holes measures 1.410" and I just had the grommet in it the breather is very tight.
I bet you 1.5" is going to be OK? Unless you already tried it, then your screwed and must weld up the cover and redill if your handy with that kind of thing.
Otherwise get another valve cover unless ford or chevy uses 1.5?
Re: SB Mickey Thompson Valve Cover Grommets/Breather [Re: Challenger 1] #1542907
12/03/13 11:25 PM
12/03/13 11:25 PM
Indy
Indy
What is the OD of the grommet you tried in the 1.410 hole?
Re: SB Mickey Thompson Valve Cover Grommets/Breather [Re: moparman89] #1542908
12/04/13 08:51 AM
12/04/13 08:51 AM
Cincinnati, Ohio
Cincinnati, Ohio
I don't have it handy to measure right now, but it came out of a stock valve cover.
Re: SB Mickey Thompson Valve Cover Grommets/Breather [Re: Challenger 1] #1542909
06/01/14 09:21 PM
06/01/14 09:21 PM
Sacramento, CA
cal_gecko Offline
cal_gecko  Offline
Sacramento, CA
web page
both of the holes on my valve covers are 1.5" ... I got a breather for one of them, but there's NO PCV grommets that size ...
Re: SB Mickey Thompson Valve Cover Grommets/Breather [Re: cal_gecko] #2742669
02/13/20 08:31 PM
02/13/20 08:31 PM
Washington
skrews Online content
skrews  Online Content
Washington
Doorman # 42324
.750 id
Bringing this back from the dead in case it can help someone.
