426 hemi mopar performance 4 bbl intake torque spec #1542618
12/02/13 02:20 PM
12/02/13 02:20 PM
englewood beach, florida
ts70rt Offline OP
ts70rt  Offline OP
can someone tell me if im installing a mopar performance alum. 4 bbl intake on a 426 hemi is the torque spec go to the regular 40 ft lbs like a 440? Thanks
Re: 426 hemi mopar performance 4 bbl intake torque spec [Re: ts70rt] #1542619
12/02/13 02:45 PM
12/02/13 02:45 PM
Chicago Blackhawks
hemicar1971 Offline
hemicar1971  Offline
Chicago Blackhawks
All I used was the same specs as the stock intake for a Street Hemi.
https://board.moparts.org/ubbthreads/show...amp;Search=true
1971 HEMI E BODY REGISTRY
Re: 426 hemi mopar performance 4 bbl intake torque spec [Re: hemicar1971] #1542620
12/04/13 02:22 AM
12/04/13 02:22 AM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
same here, factory specs, in INCH pounds.. dont forget to retighted after the engine had been run...and cools back down.
