Anyone can Recommend a Good Cooling System Stop Leak? #1541704
11/30/13 12:06 AM
11/30/13 12:06 AM
North East
MaxHeadroom Offline OP
North East
Never had much luck with these, well, maybe once. Only have used Bars Leak, I think. I have a truck, engine is tucked back, one of the metal heater hose assemblies has sprung a leak. Only way to get to it is to pull off everthing on top of engine and passenger side. My other cars are not movable in the garage, so would have to do this in the street, Lol, too cold for that. I have seen some expensive brands, Moroso Ceramic, Blue Devil ($60) and a few others. Need something to maybe hold me by until I have a place to do this. Mechanics want several hundred because everything has to be moved. What have you tried that you can recommend? Thanks.
BTW... tried a $10 bottle of Bars Heater Core, did nothing.
Re: Anyone can Recommend a Good Cooling System Stop Leak? [Re: MaxHeadroom] #1541705
11/30/13 12:20 AM
11/30/13 12:20 AM
I know it's winter but is there anyway to bypass it (or at least for awhile). Good luck
Re: Anyone can Recommend a Good Cooling System Stop Leak? [Re: RapidRobert] #1541706
11/30/13 02:06 AM
11/30/13 02:06 AM
So Cal
autoxcuda Online content
autoxcuda  Online Content
So Cal
My customers have great luck with Justice Brothers Radiator Stop Leak RSL/2. Holds up to 25 lbs of pressure. Does not contain metallics that can cause clogging with their weight.
http://www.justicebrothers.com/products_carcare_radiator_additives.htm
Re: Anyone can Recommend a Good Cooling System Stop Leak? [Re: autoxcuda] #1541707
11/30/13 09:59 AM
11/30/13 09:59 AM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
If its a metal pipe..its rusted away..nothing is gonna work..bypass it..its all u can do
Re: Anyone can Recommend a Good Cooling System Stop Leak? [Re: AARCONV] #1541708
11/30/13 11:25 AM
11/30/13 11:25 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Texas? Cold? I'm changing the fuel filters on my Massey this morning. 25 above and cloudy. But anyway, if one of your metal core pipes has sprung a leak, you have a definite possibility of a gross failure. I agree with the others, if you can't fix it, bypass it. Now speaking as someone who has done this, get used to driving with your window down and have an ice scraper handy because the inside of the windshield frosts over from your breath. No fun.
Re: Anyone can Recommend a Good Cooling System Stop Leak? [Re: 6PakBee] #1541709
11/30/13 11:35 AM
11/30/13 11:35 AM
Texas? Cold?
I was chuckling about that myself . right now it's 63 deg F at the southern tip which I assume is the Brownsville area
Re: Anyone can Recommend a Good Cooling System Stop Leak? [Re: MaxHeadroom] #1541710
11/30/13 11:47 AM
11/30/13 11:47 AM
SD
Z
zrxkawboy Offline
zrxkawboy  Offline
Z
SD
Conklin's Dike is the best, and will not clog anything.
You said you already added one kind of stop leak. No matter what you try now, you need to flush the system first. Mixing two kinds of stop leak in a system is asking for trouble.
It's Swifty! Swifty, you toad sucker!
Re: Anyone can Recommend a Good Cooling System Stop Leak? [Re: MaxHeadroom] #1541711
12/01/13 08:14 AM
12/01/13 08:14 AM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
Fix it, bypass it, or don't use it. You can't plug a leak in a hose with goo.
Re: Anyone can Recommend a Good Cooling System Stop Leak? [Re: zrxkawboy] #1541712
12/02/13 02:31 AM
12/02/13 02:31 AM
British Columbia
chrisf Offline
chrisf  Offline
British Columbia
yep, dyke (proper spelling) works great. we use it on the big truck stuff with 100% leak stoppage.
Re: Anyone can Recommend a Good Cooling System Stop Leak? [Re: chrisf] #1541713
12/02/13 07:23 PM
12/02/13 07:23 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Learned a long time ago, stop leak only causes the next weak point to leak. Can you maybe bypass it with a long heater hose so that you still get heat then replace it later?
Don't be the exception.
