will a one piece trunk floor fit through trunk opening? #1541110
11/28/13 03:56 PM
11/28/13 03:56 PM
BC Canada
O
ogopogo Offline OP
ogopogo  Offline OP
O
BC Canada
I just found out the trunk floor should be replaced on my 70 challenger and I want to use the AMD one piece panel but ive heard there is no way to get it in unless you remove 1/4 panels or tailpanel which I will not be doing.
whats the best solution/compromise?
Re: will a one piece trunk floor fit through trunk opening? [Re: ogopogo] #1541111
11/28/13 03:58 PM
11/28/13 03:58 PM
jersey shore
flypaper Offline
I hate Texas
flypaper  Offline
I hate Texas
jersey shore
all thats left is to cut it in half...
Re: will a one piece trunk floor fit through trunk opening? [Re: flypaper] #1541112
11/28/13 04:10 PM
11/28/13 04:10 PM
Waddell AZ
azblackhemi Offline
azblackhemi  Offline
Waddell AZ
I don't remember who it was but recently a thread was posted about removing the lower rear panel (the one behind the bumper) and slipping it up through there. Most of the spot welds have to be drilled to remove the trunk floor anyway. Maybe someone can find that thread? I've never tried it that way but next time I will.
Re: will a one piece trunk floor fit through trunk opening? [Re: azblackhemi] #1541113
11/28/13 05:43 PM
11/28/13 05:43 PM
Sacramento,California
JRepucci Offline
JRepucci  Offline
It was easier to Google Moparts to find the link. Roll to the bottom of the post and there is the install as one piece with tail panel and quarters in place.
https://www.google.com/url?sa=t&rct=...sse7mc6MJdT1d7Q
Re: will a one piece trunk floor fit through trunk opening? [Re: JRepucci] #1541114
11/28/13 06:10 PM
11/28/13 06:10 PM
BC Canada
O
ogopogo Offline OP
ogopogo  Offline OP
O
BC Canada
thanks guys !
Re: will a one piece trunk floor fit through trunk opening? [Re: ogopogo] #1541115
11/28/13 09:55 PM
11/28/13 09:55 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
Demon did it and he's pretty much local. B-body though.
Sheldon
Re: will a one piece trunk floor fit through trunk opening? [Re: ogopogo] #1541116
11/29/13 11:03 AM
11/29/13 11:03 AM
Wausau Wisconsin USA North Ame...
radiatorman Offline
radiatorman  Offline
I used the AMD one piece floor and got it in. But if I remember correctly, we had the Dutchman panel and hinges off to do it. I think it was more of the hinges off more than the panel.
Bob
Re: will a one piece trunk floor fit through trunk opening? [Re: radiatorman] #1541117
11/30/13 12:35 AM
11/30/13 12:35 AM
Star Idaho
67vertman Offline
67vertman  Offline
Star Idaho
That is how I did mine. I have also heard you can remove the panel under the tail panel. Or get out the and cut it in two.
Bob
Re: will a one piece trunk floor fit through trunk opening? [Re: 67vertman] #1541118
11/30/13 09:33 AM
11/30/13 09:33 AM
Ct, Oxford
340swing Online content
340swing  Online Content
Ct, Oxford
Remove the the lower panel that connects the rear frame rails. It doesn't look like it will fit but it slides in with a little patience. Rest the new panel on the frame rails and push up. car needs to be up on stands if i remember right.The initial angle is pretty steep until you clear the shock humps past the tail panel. It will go in no need to remove quarters. Mine is a 70 cuda. never did a challenger can't imagine it's any different.
Re: will a one piece trunk floor fit through trunk opening? [Re: 340swing] #1541119
11/30/13 07:25 PM
11/30/13 07:25 PM
midwest
68427vette Offline
68427vette  Offline
midwest
That should be a sticky in this section.. as reference.
