Y codes on St. Louis Fender Tag #1540749
11/27/13 08:00 PM
11/27/13 08:00 PM
Texas
Texican Offline OP
Texican  Offline OP
Texas
Question: Is it common for a St. Louis built car (1970 Charger R/T) to not have a Y-code on the fender tag ?
Mine does not....
All previous Mopars I've owned have some Y code (Y05, etc... ) listed at the top for delivery and handling, etc... but my car does not have a Y Code on the fender tag.
Is this common ?
26 END
N88 P31 R21 V21 V8X
H51 J25 J45 J81 M21 M31
B51 C21 C55 G31 G33
EK2 C6K4 FK5 211 M99220
E86 D32 XS29 UOG 1891xx
Thanks for any insight..
Re: Y codes on St. Louis Fender Tag [Re: Texican] #1540750
11/27/13 08:50 PM
11/27/13 08:50 PM
MI
John L Offline
John L  Offline
MI
No Y codes on my fender tag, 70 Charger RT.
John
Re: Y codes on St. Louis Fender Tag [Re: Texican] #1540751
11/27/13 09:04 PM
11/27/13 09:04 PM
Great White North
Furyman Offline
Furyman  Offline
Great White North
Fairly common to see Y14 and Y16 on 70 tags...lots of tags with no Y codes.Your 70 was on egag in 2012....I have it on my database as FK5 not EK2.
"Long Live Mopars"
Re: Y codes on St. Louis Fender Tag [Re: Texican] #1540752
11/27/13 09:08 PM
11/27/13 09:08 PM
Lansing, MI
70gtx440dana Offline
Lansing, MI
Mine does not....
Is this common ?
26 END
N88 P31 R21 V21 V8X
B51 C21 C55 G31 G33
I just looked at 50 or so photos of SL tags that I have for saved for 70 Chargers & other B bodies. Many of the tags have no "Y" code. The "Y" codes I see that is somewhat common is Y16 (sales bank), also a few Y07 (build to spec Canada) and one Y09 (build to spec export). Interesting that of all the tag photos I have non of them have Y05 (build to spec US). Hope this helps you out a bit.
70 Road Runner 383-4 4 speed FJ5 & black guts
70 Charger R/T 440-4 4 speed FJ5 & white guts
Re: Y codes on St. Louis Fender Tag [Re: Furyman] #1540753
11/27/13 11:10 PM
11/27/13 11:10 PM
Texas
Texican Offline OP
Texican  Offline OP
Texas
Hi
Nope, Except for the upper door frame, it's EK2 Mango all over.
Here's a pic of it in my shop still wearing it's original paint.
Documented previous owner Ted Stephens (Stephens Performance Mopar)...
What kind of database are your putting together, Chargers ?
Re: Y codes on St. Louis Fender Tag [Re: Texican] #1540754
11/27/13 11:44 PM
11/27/13 11:44 PM
Great White North
Furyman Offline
Furyman  Offline
Great White North
Corrected my entry...thanks.I've been doing some yearly spreadsheets...collecting info on everything mopar.It's a good hobby...costs only time...info is free.It's always neat when you get a consecutive VIN or order #.I've only got 10K or so organized ...model/eng/plant/yr/vin/order # etc etc.Probably have another 10k on paper from pre computer days and have at least 15K jpegs of fender tags ,broadcasts,pics etc. Need to figure out how to link the pics to the database.Heres a tip...when you right clic and save an image change the img # to the Vin # right away before you get too many on your hard drive.Multiple images of the same vehicle just add bcs,ft,inv etc to the Vin # .I've been spending an hour a nite lately trying to renumber mine.....thousands to go lol.
"Long Live Mopars"
Re: Y codes on St. Louis Fender Tag [Re: Texican] #1540755
11/28/13 12:22 PM
11/28/13 12:22 PM
Harlan, Iowa
69CoronetRT Offline
69CoronetRT  Offline
Harlan, Iowa
STL was inconsistent with Y codes. You will find it occasionally but not having a Y code on a STL car is more common than having one.
Seeking:
1969 St. Louis plant VINs, SPD, and VONs.
Over 2,000 thanks to you!
Re: Y codes on St. Louis Fender Tag [Re: 69CoronetRT] #1540756
11/28/13 12:49 PM
11/28/13 12:49 PM
Texas
Texican Offline OP
Texican  Offline OP
Texas
Good information... Thanks to all.
