1992 150 Questions #1540121
11/26/13 01:15 PM
11/26/13 01:15 PM
Kentucky
dfsmopars Offline OP
Kentucky
I have the opportunity to buy an original '92 150 with a 318. Approximately 80,000 miles.
What transmission is it going to have and is the speedo in the cluster electronic or is it still mechanical?
Any other thoughts about this model truck would be appreciated because I am going to hopefully look at it tomorrow.
I have never owned one of that year.
‘72 Charger, 5.9 Magnum, Tremec 5 spd., Pro-Touring
‘14 Big Horn, Quad Cab, 4x4, 1500
Re: 1992 150 Questions [Re: dfsmopars] #1540122
11/26/13 01:55 PM
11/26/13 01:55 PM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
5.2 Magnum Most likely a 518 hydraulic transmission which means electronic speedo.
Excellent truck to buy with 80K on the clock
They are the perfect donor to use when doing a Magnum swap in a older 72-91 truck that's what I use them for
Re: 1992 150 Questions [Re: BulletBob] #1540123
11/26/13 02:07 PM
11/26/13 02:07 PM
Washington Twp., Southern NJ
Fastfrankie Offline
Fastfrankie  Offline
How is the 518 auto/overdrive regarding longevity with regular tranny fluid changes under normal use - NO towing.
Re: 1992 150 Questions [Re: dfsmopars] #1540124
11/26/13 02:29 PM
11/26/13 02:29 PM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
Pluses :
The 318 Mag power will put a smile on your face. Overall bullet proof everything and simple to work on. Very rust resistant body.
Minus:
Those early overdives are hit and miss for reliability. Rough ride,plenty of road/windnoise, hideous looking grille, and small cab. Not deserved but a Peasant stigma attached to them.
I've owned three and have a love/hate relationship with them. Honestly, if you have to spend any time behind the wheel you are better off with a 2 Gen, which, even to this day no other manufacturer has matched.
Mo' Farts
Moderated by "tbagger".
Re: 1992 150 Questions [Re: Grizzly] #1540125
11/26/13 04:04 PM
11/26/13 04:04 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
I know it's only got 80K on it but still take a close look at the gutter lip on the roof of the cab, especially at the front, they like to rust there. It seemed that the 94 and later had the problems with the trannys more than the early ones (cheap parts used). Overall good trucks, should have alot of scoot with the 5.2 Magnum and a reasonable weight (unlike the later generations). Also watch for the intake gasket in the bottom plate leaking oil into the intake, common problem
Re: 1992 150 Questions [Re: Fastfrankie] #1540126
11/26/13 04:11 PM
11/26/13 04:11 PM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
I removed one with 155K on it & shifted it using switches & it went another 50+K before it went out
I towed regular & it was in my LWB CrewCab
Re: 1992 150 Questions [Re: Fastfrankie] #1540127
11/26/13 05:03 PM
11/26/13 05:03 PM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
My wife's Ramcharger made it to 228,000 with some towing. I didn't push it to the end, had converter shudder and flared on an upshift once if I remember right. Slipped @ heavy throttle towing. Now at 316,000 miles, going strong.
Robert
'68 Fury Convertible
'69 300 Convertible
'15 Durango 5.7 Hemi
'16 300 S Hemi
Re: 1992 150 Questions [Re: dfsmopars] #1540128
11/26/13 06:41 PM
11/26/13 06:41 PM
Kentucky
Kentucky
Set up to go look at the truck tomorrow.
Re: 1992 150 Questions [Re: dfsmopars] #1540129
11/26/13 07:31 PM
11/26/13 07:31 PM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
My transmission guy says that if you put a OD unit from a 97-02 518 that the 46RH trans will last a long time Improved cooling in those units
He's built transmissions & rearends in a Chrysler dealer for 27 years now
94-96 trannys were built cheaply
Re: 1992 150 Questions [Re: dfsmopars] #1540130
11/26/13 08:10 PM
11/26/13 08:10 PM
Salem
Grizzly Offline
Grizzly  Offline
Salem
Is it a four-wheel drive, dfs?
Mo' Farts
Re: 1992 150 Questions [Re: Grizzly] #1540131
11/26/13 10:19 PM
11/26/13 10:19 PM
Kentucky
Kentucky
2WD Around my house it is a rare bird. Most that survived are diesel or just beat all too pieces. This one looks clean.
Re: 1992 150 Questions [Re: dfsmopars] #1540132
11/26/13 10:41 PM
11/26/13 10:41 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
I bought a new 92 D150 2WD, 318 Magnum. I loved the engine and trans, power and fuel mileage. The seat and interior were cheaper than earlier years and I didn't love the grille but that was all forgotten when I was smoking big block pickups of other manufacture. Great truck.
Sheldon
Re: 1992 150 Questions [Re: RUNCHARGER] #1540133
11/26/13 11:01 PM
11/26/13 11:01 PM
Kentucky
Kentucky
It's funny those who hate on the 91-93 grills but that is what attracts me to them. As they say, "To each his own."
Re: 1992 150 Questions [Re: dfsmopars] #1540134
11/26/13 11:06 PM
11/26/13 11:06 PM
Salem
Grizzly Offline
Grizzly  Offline
Salem
2wd? Good deal. Just one more thing to look out for will be a worn steering coupler.
I was going to mention if it's 4wd all the grief you can expect with that miserable solid front axle: Outer U-joints, ball joints, axle seals, just anything that has to be done on them is a pain and you need special tools. And they all fail in one way shape or form well before 100k.
The Engineer that dreamt up the straight-axle Dodges must have discovered a Mechanic sleeping with his Wife.
*edit*
Wow, if that's it you better scoop that thing up.
Mo' Farts
Re: 1992 150 Questions [Re: Grizzly] #1540135
11/27/13 02:26 AM
11/27/13 02:26 AM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
The Dodge Brothers invented 4WD & FWD
What 2nd gen has IFS & 4WD
I've owned quite a few 2nd gen trucks & they don't ride any better than the 93 down truck
Re: 1992 150 Questions [Re: dfsmopars] #1540136
11/27/13 04:18 PM
11/27/13 04:18 PM
Kentucky
Kentucky
Bought the truck. As advertised it does run good. Cruise, AC, tilt, PW & PL. Odometer does not work but everything else seems to. There is a ratchet strap securing the trans but I'll get to the bottom of that. Small amount of body rust and the left floor board needs a small repair but nothing major. I'm thinking it is going to be OK. I appreciate the input.
Re: 1992 150 Questions [Re: dfsmopars] #1540137
11/27/13 04:34 PM
11/27/13 04:34 PM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
Good luck Darrel! You know the Magnum either runs good or it doesn't run at all & will last a long time
A testament to this is the amount of B series vans still in service from those years
Re: 1992 150 Questions [Re: dfsmopars] #1540138
11/27/13 05:14 PM
11/27/13 05:14 PM
Canada
demon Offline
demon  Offline
Canada
Those are great trucks. I have a near identical 92 that I got for next to nothing.
You know that you can swap on 72-80 fenders, doors and box and make it look like a 70's truck. That's what I might do with mine. Most people will never notice the squared up roof skin. I would like to find a shortbox 92-93 and swap on the 70's parts and paint it up like a Macho Power Wagon. Best of both worlds
Re: 1992 150 Questions [Re: demon] #1540139
11/27/13 05:26 PM
11/27/13 05:26 PM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
That beats what I've been doing with them
Re: 1992 150 Questions [Re: dfsmopars] #1540140
11/27/13 08:18 PM
11/27/13 08:18 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
The speedometer/odometer problems are somewhat common on the elec speedos, but usually hit trouble at higher 150k or so miles, on mine anyway.
