Electrical issue ebody help #1539578
11/25/13 03:57 AM
11/25/13 03:57 AM
I DA HOE
3
3406pac Offline OP
3406pac  Offline OP
I DA HOE
Not sure if they are related, but.
The E flasher would only work with the blinker lever up/ down.
The dome light doesn't work with the knob (door open OK )
Then the dash lights went out, the fuse was blown for "console" (left side 4th from bottom). Tried 2 more fuses no help of course.
I get 12 volts and 1.3 amps at fuse, same as rest of fuses.
Not sure where to start.
It is a new resto, with new under dash harness only.
AAR cuda 71 rag challenger
Re: Electrical issue ebody help [Re: 3406pac] #1539579
11/25/13 01:29 PM
11/25/13 01:29 PM
PORT ALBERNI , BC., CANADA
superwrench Offline
superwrench  Offline
Do you have the old dash harness?? If you do, I'd start by comparing the wire routing to the new harness.
Sounds to me that there could be some wires not in the right places. It certainly wouldn't be the first time that a reproduction harness is bad. I just went thru a nightmare with a harness for a Dart.
Re: Electrical issue ebody help [Re: superwrench] #1539580
11/25/13 01:34 PM
11/25/13 01:34 PM
I DA HOE
3
3406pac Offline OP
3406pac  Offline OP
I DA HOE
I have the old harness but nothing got marked.
And no schematic, hopefully YO can get me one, as I purchased it from them.
Was your harness a YO item?
Are your wire colors the same as factory?
Plugs the same also?
I have several plug ends with nothing plugged in.
Yet several items not installed such as cig lighter light, map light, glove box light and ign key light ,,,
Re: Electrical issue ebody help [Re: 3406pac] #1539581
11/25/13 02:31 PM
11/25/13 02:31 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
When installing a new harness, you need to lay out both harnesses next to each other. Compare the new harness to the old one. Make sure the wire colors are the same and make sure they are going to the same place. Also check every connector to make sure everything is tight.
I hope you did that and just didn't install the harness without looking it over.
