Not sure if they are related, but.
The E flasher would only work with the blinker lever up/ down.
The dome light doesn't work with the knob (door open OK )
Then the dash lights went out, the fuse was blown for "console" (left side 4th from bottom). Tried 2 more fuses no help of course.
I get 12 volts and 1.3 amps at fuse, same as rest of fuses.
Not sure where to start.
It is a new resto, with new under dash harness only.
AAR cuda 71 rag challenger
