70 cuda grille chrome inserts #1539421
11/24/13 09:57 PM
11/24/13 09:57 PM
I DA HOE
3
3406pac Offline OP
3406pac  Offline OP
I DA HOE
How do you remove the retainers on the back without braking?
Besides very carefully.
AAR cuda 71 rag challenger
Re: 70 cuda grille chrome inserts [Re: 3406pac] #1539422
11/24/13 09:59 PM
11/24/13 09:59 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
small tip needle nose pliers
Re: 70 cuda grille chrome inserts [Re: gtx6970] #1539423
11/24/13 11:05 PM
11/24/13 11:05 PM
I DA HOE
3
3406pac Offline OP
3406pac  Offline OP
I DA HOE
So bend the friction ears?
They are delicate as this is brand new and the resto shop broke 4.
I want to try super glue on the broke ones
Re: 70 cuda grille chrome inserts [Re: 3406pac] #1539424
11/24/13 11:56 PM
11/24/13 11:56 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
The clips are A LOT cheaper then the chrome inserts
Re: 70 cuda grille chrome inserts [Re: gtx6970] #1539425
11/25/13 12:03 AM
11/25/13 12:03 AM
I DA HOE
3
3406pac Offline OP
3406pac  Offline OP
I DA HOE
Should have been more clear, they broke the pins that the clips go over.
Re: 70 cuda grille chrome inserts [Re: 3406pac] #1539426
11/25/13 11:22 AM
11/25/13 11:22 AM
Lee Co. Fla.
5carguy Offline
5carguy  Offline
Lee Co. Fla.
I use a small U shaped pick.Work it under the gripping tabs.
Re: 70 cuda grille chrome inserts [Re: 3406pac] #1539427
11/25/13 05:30 PM
11/25/13 05:30 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Sounds like you need the chrome inserts
http://beaparts.com/list_items.aspx?body=E&cat=E&subcat=22
