Header tethers #1539391
11/24/13 09:28 PM
11/24/13 09:28 PM
Y-town ohio
68valiant68 Offline OP
Y-town ohio
http://www.nic-fab.com/collector-cable.html
If you have to get them, check these out they are way cheaper than anything else I have seen.
Re: Header tethers [Re: 68valiant68] #1539392
11/24/13 09:58 PM
11/24/13 09:58 PM
in front of the computer
8
80arrow Offline
80arrow  Offline
Thanks for the heads up and link
Re: Header tethers [Re: 80arrow] #1539393
11/24/13 10:03 PM
11/24/13 10:03 PM
Out West
408strokerdart Offline
Out West
About $40 in parts, so these are much more reasonably priced than the "Collector Tethers".
Re: Header tethers [Re: 408strokerdart] #1539394
11/24/13 10:08 PM
11/24/13 10:08 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
added these to my favorites so when I am ready this spring.
Re: Header tethers [Re: 68valiant68] #1539395
11/24/13 10:11 PM
11/24/13 10:11 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
I had to laugh when I first read of this new NHRA rule. But since then I have witnessed 2 Borla mufflers come off race cars going down the track. Didn't cause a accident but the cars did get upset buy running them over. I don't know if it was a bracket failure or a maintenance failure by not checking the bolt/nut. The tethers seem to be a little over priced, a couple of t-bolt clamps a foot of cable should be under 20 bucks, but then again, it's for NHRA safety rules.
Re: Header tethers [Re: rowin4] #1539396
11/24/13 10:22 PM
11/24/13 10:22 PM
Moparts
SSDart Offline
SSDart  Offline
Moparts
I work at my local track once in awhile running the lanes. It is amazing how many poeple have come up yo me with burnt hands from picking up collectors and mufflers that come off.........
Re: Header tethers [Re: SSDart] #1539397
11/24/13 10:37 PM
11/24/13 10:37 PM
8
80arrow Offline
80arrow  Offline
Would you still have to use these teathers if you weld the collector to just one of the primaries?
Re: Header tethers [Re: 80arrow] #1539398
11/24/13 10:53 PM
11/24/13 10:53 PM
Moparts
SSDart Offline
SSDart  Offline
Moparts
If you weld with a one in stitch on 2 primaries I believe your ok....
Re: Header tethers [Re: SSDart] #1539399
11/25/13 09:28 AM
11/25/13 09:28 AM
Mid west
Gearhead383 Offline
Gearhead383  Offline
Mid west
As per the 2014 rule amendments:
Exhaust collectors/stacks must be securely fastened (i.e., metal connector straps, bolted, welded, etc.) to prevent loss of collector/stacks during competition. All removable multi-piece exhaust collectors/stacks must be securely fastened with either an NHRA-accepted header tether, or a minimum ½” (half-inch) stitch weld located on each primary tube to prevent loss of collector/stacks during competition. A current list of NHRA-accepted header tethers is available on NHRARacer.com.
Re: Header tethers [Re: Gearhead383] #1539400
11/25/13 10:50 AM
11/25/13 10:50 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
yeah....but the $200 ones were so pretty!
Re: Header tethers [Re: J_BODY] #1539401
11/25/13 11:01 AM
11/25/13 11:01 AM
Aurora, Oh.
max_maniac Offline
max_maniac  Offline
Aurora, Oh.
There is an ad in ND that has header tethers advertised for $49.99 and another set for $99.99 IIRC...... A bit more affordable then the $200.00 ones!!
Russ
Re: Header tethers [Re: max_maniac] #1539402
11/25/13 12:55 PM
11/25/13 12:55 PM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
If I remember correctly 4-1/4" by 3/4" grade 8 bolts and 4-1/4" lock nuts was under $2.00 at Marvin's .
"To Be The Man'You Have Got To Beat The Man" "T/D and Pro-Bracket Racer"
Re: Header tethers [Re: MRMOPAR622] #1539403
11/25/13 02:45 PM
11/25/13 02:45 PM
Aurora, Oh.
max_maniac Offline
max_maniac  Offline
Aurora, Oh.
But can you get them with an NHRA approved tag
Russ
Re: Header tethers [Re: max_maniac] #1539404
11/26/13 01:53 PM
11/26/13 01:53 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
I'am all for saftey,but how are these tethers any more safer than welded and bolted metal straps on each side of the collecter to the primary tubes?We use two straps and 4 tabs 1/2 inch wide with 1/4 inch bolts with stover style lock nuts.Cost of materials under $10.Header manufactures have been doing it this way for years.I would think that they should be acceptable.
Re: Header tethers [Re: B G Racing] #1539405
11/26/13 02:00 PM
11/26/13 02:00 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
They are required because so many people NEVER do any maintenance to their cars. Thus not catching when tabs break or bolts come off. Just another case of all of us paying for the mistakes of others. Just like insurance....
FWIW I have seen this happen on three seperate occasions and always on dragsters. Where it should be easily seen if guys ever looked at their junk. Imagine tire shake is causing it to happen.
Re: Header tethers [Re: max_maniac] #1539406
11/26/13 06:06 PM
11/26/13 06:06 PM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
Russ
I not sure but it seems to be Bob George Racing approved,and that's good enough for me.
Re: Header tethers [Re: MRMOPAR622] #1539407
11/26/13 08:12 PM
11/26/13 08:12 PM
Central Ohio, USA
Bigbeep Offline
Bigbeep  Offline
Central Ohio, USA
Lets just see how many racers get booted for not having them. When this stuff starts hitting the tracks pocket book, the tracks will let them race. Its no different then helmets and belts. When they are even checked, that is. I believe in safety first, but I also nut and bolt my car every couple of races. Beep
Re: Header tethers [Re: Al_Alguire] #1539408
11/26/13 08:23 PM
11/26/13 08:23 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
And what happens when they don't maintain the teathers and they fall off?
Doug
Re: Header tethers [Re: dvw] #1539409
11/26/13 08:39 PM
11/26/13 08:39 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Doug
Yeah,I would like to see how those long tie rods last under severe vibration and other types of harmonics.The shorter the connecting method the stronger.We still maintain the standard flat bar and tabs will do the job.We have never lost a collecter in all the years We've raced.To disallow this method is stupid imo.
Re: Header tethers [Re: 68valiant68] #1539410
11/26/13 08:56 PM
11/26/13 08:56 PM
Galesburg IL.
dillon383 Offline
dillon383  Offline
Galesburg IL.
Here is another option for the same price. http://www.rjracecars.com/QM-Clamp-On-Collector-Tether-System-Prodview.html Also they are running a black Friday sale to save 10%, so that helps a little.
