E-Body Glove Box Door (Stud Threads Stripped) #1539013
11/23/13 10:24 PM
11/23/13 10:24 PM
California, USA
filmsurgeon Offline OP
California, USA
See attached photos. One of the studs on my glove box door (for the open/stop bracket) has stripped threads (actually, they're totally gone). Does anybody have any suggestions on the best way to remedy this problem, other than buying a replacement/used door? I already tried putting JB Weld on the stud, and then tried rethreading it with a nut, but that did not work. Thanks.
Re: E-Body Glove Box Door (Stud Threads Stripped) [Re: filmsurgeon] #1539014
11/23/13 10:38 PM
11/23/13 10:38 PM
Sacramento,California
JRepucci Offline
JRepucci  Offline
Easiest fix... replace the door.
Re: E-Body Glove Box Door (Stud Threads Stripped) [Re: JRepucci] #1539015
11/23/13 10:44 PM
11/23/13 10:44 PM
In the 8's
FY1TA Offline
FY1TA  Offline
In the 8's
Try a 6mm nut .
Re: E-Body Glove Box Door (Stud Threads Stripped) [Re: FY1TA] #1539016
11/23/13 10:47 PM
11/23/13 10:47 PM
California, USA
California, USA
Try a 6mm nut .
Thanks, but would prefer to keep it looking original with the #8x32 cap nut.
Re: E-Body Glove Box Door (Stud Threads Stripped) [Re: filmsurgeon] #1539017
11/24/13 03:20 AM
11/24/13 03:20 AM
JRepucci Offline
JRepucci  Offline
I have an extra door...
Re: E-Body Glove Box Door (Stud Threads Stripped) [Re: JRepucci] #1539018
11/24/13 11:18 AM
11/24/13 11:18 AM
mopar346 Offline
Let me tell ya about fat chicks!
mopar346  Offline
The one will hold it especially the way they are treated now. Tighten the good one properly and glue/silicone/jb weld the bad one onto the stud. Be clean about it and no one will know and then when the dash is done you can replace it. In the meantime keep an eye out for one with the sheen/fade to match your current dash and swap them out if you find something you think is undetectable.
Careful, your character's showing!
Re: E-Body Glove Box Door (Stud Threads Stripped) [Re: mopar346] #1539019
11/24/13 02:39 PM
11/24/13 02:39 PM
Mrytle Beach SC
johnscudashop Offline
Mrytle Beach SC
Re: E-Body Glove Box Door (Stud Threads Stripped) [Re: filmsurgeon] #1539020
11/25/13 03:20 AM
11/25/13 03:20 AM
California, USA
California, USA
So ... Here's the outcome. Taking the advice of all, I came up with a collective solution.
1) I cut off the the stud flush with the back of the door using a dremel and cut-off wheel.
2) I drilled out the remainder of the stud using a bit the same size as the stud.
3) I located a screw with the correct thread (#8x32). This happened to be a screw with a combination (flat/phillips) round head.
4) I used a drill bit the same diameter as the screw head to recess the stud hole.
5) After being satisfied with the test fitting, I roughed up the head with emery cloth and applied epoxy into the hole; then set the screw head in place.
6) After the epoxy cured, I cut off the excess screw threads to be the correct height as the original (1/4").
7) It's now ready for paint.
Thanks everyone for the suggestions and inspiration.
Re: E-Body Glove Box Door (Stud Threads Stripped) [Re: filmsurgeon] #1539021
11/25/13 09:09 AM
11/25/13 09:09 AM
London, England
Gavin Offline
Gavin  Offline
London, England
Nice solution
