best atf ? #1538979
11/23/13 09:18 PM
11/23/13 09:18 PM
ohio
ffej Offline OP
ffej  Offline OP
ohio
got a new tranny from crt, manual valve body and such. what tranny fluid would work best? thanx jeff
Re: best atf ? [Re: ffej] #1538980
11/23/13 09:55 PM
11/23/13 09:55 PM
Many people on here are comfortable with type F
Re: best atf ? [Re: RapidRobert] #1538981
11/23/13 09:59 PM
11/23/13 09:59 PM
ohio
ffej Offline OP
ffej  Offline OP
ohio
any brand better than others?
Re: best atf ? [Re: ffej] #1538982
11/23/13 10:06 PM
11/23/13 10:06 PM
Good question & I ain't sure on that. Me too with alot of $$$ invested I'd want the best. I'd maybe ask John Cope at CRT & see what he recommends. He has a good rep on here
Re: best atf ? [Re: RapidRobert] #1538983
11/23/13 10:10 PM
11/23/13 10:10 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Hey Jeff,
I run Type F in the Charger. No manual valve body though. From what I read, even the stuff you'd get from Wal Mart works fine.
Re: best atf ? [Re: RapidRobert] #1538984
11/23/13 10:16 PM
11/23/13 10:16 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
That's the best choice...
Re: best atf ? [Re: ffej] #1538985
11/24/13 08:43 AM
11/24/13 08:43 AM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
Walmart.
Re: best atf ? [Re: Commando1] #1538986
11/24/13 11:13 AM
11/24/13 11:13 AM
Buford, GA
I_bleed_MOPAR Offline
Buford, GA
Walmart.
Asked this question last year on the race board. Practically unanimous to run Type F from WallyWorld.
Tim
'71 Charger 383/727
'17 Challenger SXT (Wifeys car wink )
Re: best atf ? [Re: ffej] #1538987
11/24/13 11:41 AM
11/24/13 11:41 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
I see from just a quick check of CRT's site that CRT RECOMMENDS ATF+3 with their 727/904 manual valve equipped trannys or PENNSOIL DEXTRON II or III , but again, being it's a new tranny, and that usually means warranty coverage, I'd contact John/CRT to see their actual intended fluid for your application...
Re: best atf ? [Re: DAYCLONA] #1538988
11/24/13 12:08 PM
11/24/13 12:08 PM
SD
Z
zrxkawboy Offline
zrxkawboy  Offline
Z
SD
PENNSOIL DEXTRON
I wonder if Pennzoil Dexron would work?
It's Swifty! Swifty, you toad sucker!
Re: best atf ? [Re: zrxkawboy] #1538989
11/24/13 01:48 PM
11/24/13 01:48 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
PENNSOIL DEXTRON
Didn't your Mama tell ya not to shoot the messenger?...
Verbatim from CRT's site...
Re: best atf ? [Re: DAYCLONA] #1538990
11/24/13 03:18 PM
11/24/13 03:18 PM
SD
Z
zrxkawboy Offline
zrxkawboy  Offline
Z
SD
Just jokin' with ya!
Re: best atf ? [Re: zrxkawboy] #1538991
11/24/13 03:50 PM
11/24/13 03:50 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
I know...
Re: best atf ? [Re: DAYCLONA] #1538992
11/24/13 04:22 PM
11/24/13 04:22 PM
ohio
ffej Offline OP
ffej  Offline OP
ohio
thanx for the info jeff
Re: best atf ? [Re: ffej] #1538993
11/24/13 06:30 PM
11/24/13 06:30 PM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
So is the conclusion here that a manual valve body 727 would use a different fluid than auto valve body (atf+3 in the manual versus type F in the auto)?
Thanks.
Facts are stubborn things.
Re: best atf ? [Re: larrymopar360] #1538994
11/25/13 01:29 AM
11/25/13 01:29 AM
Aurora, Oh.
max_maniac Offline
max_maniac  Offline
Aurora, Oh.
The best stuff is the RED stuff!!! Thats what I use....
Russ
Re: best atf ? [Re: max_maniac] #1538995
11/25/13 09:21 AM
11/25/13 09:21 AM
Chicago illinois
ChinooK440 Offline
ChinooK440  Offline
Chicago illinois
atf+3 WAS a good choice about a decade ago when it was still being made
Re: best atf ? [Re: ChinooK440] #1538996
11/25/13 11:35 AM
11/25/13 11:35 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
You are correct, a quick search shows Chrysler stopped making it in 2005....ATF+4 is the recommended replacement for vehicles requiring ATF+3
But again this thread should not have existed, the OP should have contacted Cope directly for the required ATF required for his application, so as not to void any warranty
Re: best atf ? [Re: DAYCLONA] #1538997
11/25/13 02:03 PM
11/25/13 02:03 PM
AL
jglen490 Offline
jglen490  Offline
AL
ATF+3 is no longer made. ATF+4 is the recommended solution, unless your rebuilder provides a great warranty and wants something else in there.
Re: best atf ? [Re: jglen490] #1538998
11/26/13 05:50 PM
11/26/13 05:50 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
I'm not a tranny pro, but as I understand it, common wisdom is that ATF+4 and most other newer formulations are formulated to offer less friction, and more slip because most people don't want to feel the shift in their new car AT's. They do, however resist heat a little better than the older fluids, and one would think they may last longer without breaking down. Type F is an older formulation that has been around a long time, and generally offers more friction; i.e.: less slip at the clutches during a shift. Many racers and performance minded guys like the Type F because of this.
We're talking about very small amounts of difference, however. Most would never know the difference.
FWIW: I run Type F in my manual valve-body 727, and it works just fine.
