Hemi Valve Adjustment #1538767
11/23/13 03:30 PM
11/23/13 03:30 PM
Wisconsin
Mopar_Mudder Offline OP
Wisconsin
I have a 471 Hemi with alum heads and a hydraulic cam. I have been hearing what sounds like a lifter or valve train tick back in the #5 or 7 cylinder area. I just did a compression test and came up with this:
#1 - 190 : 190 - #2
#3 - 190 : 190 - #4
#5 - 190 : 195 - #6
#7 - 175 : 185 - #8
So I pulled the driver side valve cover, major PITA with power brakes
Nothing looks terribly loose or out of wack. You can push down slightly on the lifter to cause it to be loose but I am guessing that is just the hydraulic part. I have messed with hydraulic in a long time as my other motor is solid roller, way easier to adjust. Always seems like I am guessing on hydraulic, any tips.
Plugs are also looking rich, but strangely the #7 that is low on compression is one of the better looking plugs.
1971 Hemi Cuda 2005 SRT-10 Regular Cab Flame Red. 12.771 @ 109.67<---TIME SLIP--Video
Re: Hemi Valve Adjustment [Re: Mopar_Mudder] #1538768
11/23/13 03:50 PM
11/23/13 03:50 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
This is the simplest and the most accurate method taught to me 40 years ago. it has never failed me.
A remote starter switch will be very helpful for this process
Hydraulic lifters can be set, hot or cold, pumped up or not using this procedure. It will also work for an initial set up on a solid lifter motor.
For Hydraulics, most manufacturers want .020-.040 preload. If you have a 3-8 x 24 adjuster, 1” divided by 24 TPI = .0416” so 1/2 turn beyond zero lash, will = .020 , 3/4 turn will = .030.
I like to start at the LF corner of the motor. (exhaust) Turn the engine over in the direction of rotation until the intake valve for that cylinder is almost closed. You can now adjust the exhaust valve for that cylinder.
Loosen the adjusting nut until the pushrod spins freely between your finger tips. While spinning the pushrod slowly tighten the adjusting screw, when you find zero lash your will feel a definite change in resistance to spinning the pushrod. You may want to repeat this a few times to get the “feel”. Once zero lash is found, add 1/2 to 3/4 of a turn and lock the adjuster.
Move to the next valve in line (intake). Rotate the motor in the direction of rotation until the exhaust valve for that cylinder just begins to open. Repeat the above adjustment procedure.
Repeat the process for the remaining cylinders.
Summary:
Adjust the exhaust as the Intake is almost closed
Adjust the intake as the exhaust just starts to open
Re: Hemi Valve Adjustment [Re: TJP] #1538769
11/23/13 04:13 PM
11/23/13 04:13 PM
Wisconsin
Wisconsin
Thanks, that is the same way I do my solid cam. For me the hard part is feeling that "0" lash to know when to do the 3/4 of a turn.
Re: Hemi Valve Adjustment [Re: Mopar_Mudder] #1538770
11/23/13 05:13 PM
11/23/13 05:13 PM
I wiggle the pushrod up & down with my thumb/forefinger & I can tell when the clearance just gets to zero & usually I'll repeat several times in quick sucession to get it dead on. Spinning can be misleading due to the fit on either end & the oil/breakin lube type used.
Re: Hemi Valve Adjustment [Re: Mopar_Mudder] #1538771
11/23/13 05:42 PM
11/23/13 05:42 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
"Think" about what you are trying to accomplish
If you loosen it until you have a bit of play up and down the pushrod will roll very freely as there is no pressure on the tips.
Then slowly begin tightening while rolling the pushrod between your thumb and forefinger,
when your reach zero lash, there will be a very distinct difference in the resistance as you have removed the clearance and are beginning to add pressure to the tips. IE: ZERO LASH
If you want, loosen it slightly to verify that the resistance goes away, retighten and you should find the adjustment is exactly the same.
Try it, Repeat it several times and I believe you may go WOW!!! that was simple.
Then add your preload, tighten the locknut and go onto the next
Re: Hemi Valve Adjustment [Re: TJP] #1538772
11/23/13 06:28 PM
11/23/13 06:28 PM
Horsham, Pa.
Finoke Offline
Finoke  Offline
Horsham, Pa.
Could be an exhaust manifold leak? The compression test has all cylinders within 10%. Is the spec <10%? I forget.
Re: Hemi Valve Adjustment [Re: Finoke] #1538773
11/23/13 06:41 PM
11/23/13 06:41 PM
Wisconsin
Wisconsin
I have searched for a exhaust leak and can't find one. Also my experience with exhaust leaks is that they usually go away or get much quieter when you let of the gas. This seems to be more RPM related then throttle position.
Re: Hemi Valve Adjustment [Re: TJP] #1538774
11/23/13 08:45 PM
11/23/13 08:45 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Should he take into consideration that he has Aluminum heads which grow more, and need a little more preload?
Re: Hemi Valve Adjustment [Re: 71birdJ68] #1538775
11/23/13 10:06 PM
11/23/13 10:06 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
IMO No, the potential for change is miniscule, IE: hydraulic lifter preload can be between .020 to .040. I doubt the aluminum heads will change enough to impact those numbers significantly.
If one is going for the last 2 HP then do the adjustments HOT, OUCH on the fingers LOL.
Re: Hemi Valve Adjustment [Re: TJP] #1538776
11/24/13 12:57 PM
11/24/13 12:57 PM
Wisconsin
Wisconsin
Ok I readjusted the Drive side bank. Feels like they are had about 1/4 turn of preload on them except exhaust on #7 was at about "0"
Here are my compressions now
Before : After
#1 190 : 180
#3 190 : 180
#5 190 : 180
#7 175 : 175
So should I be worried about loosing 10# on 1-3, makes is sound like they are too tight?
Re: Hemi Valve Adjustment [Re: Mopar_Mudder] #1538777
11/24/13 01:02 PM
11/24/13 01:02 PM
I'm not sure but are they quiet now?
Re: Hemi Valve Adjustment [Re: RapidRobert] #1538778
11/24/13 01:07 PM
11/24/13 01:07 PM
Wisconsin
Wisconsin
I haven't put it back together to run it yet.
Re: Hemi Valve Adjustment [Re: Mopar_Mudder] #1538779
11/24/13 01:39 PM
11/24/13 01:39 PM
Benton, IL.
DaveRS23 Online rolleyes
Special needs idiot
DaveRS23  Online Rolleyes
Special needs idiot
Benton, IL.
I wouldn't trust a comp test until after I had run it and the lifters had a chance to settle in with the new adjustments. Right now you do not know if number 7 was mis-adjusted to begin with or if you have more serious problems afoot. Pulling that lifter is the only way to know now.
Master, again and still
Re: Hemi Valve Adjustment [Re: DaveRS23] #1538780
11/24/13 03:05 PM
11/24/13 03:05 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Compression tests should always be done warm to get the most accurate readings.
I would keep good notes on your findings and recheck #7 after 500 or so miles. If it loosens up again it could be an indication of the camshaft going away. hopefully not
Another option would be to mount a dial indicator and check your lift comparing the readings between cylinders. Again this should be done on a warm motor to make sure the lifters are pumped up. IF a lobe is wearing it will show less lift. I would start with number 7 as that is the suspect cylinder.
Re: Hemi Valve Adjustment [Re: TJP] #1538781
11/24/13 04:17 PM
11/24/13 04:17 PM
Wisconsin
Wisconsin
I rechecked them again as I forgot to hook up the battery charger this time like I did last time. Now I get these numbers, look better
Before : After
#1 190 : 185
#3 190 : 185
#5 190 : 185
#7 175 : 180
Think I will pull the other side apart and check them while I am at it.
Re: Hemi Valve Adjustment [Re: Mopar_Mudder] #1538782
11/24/13 06:46 PM
11/24/13 06:46 PM
BC Canada
O
ogopogo Offline
ogopogo  Offline
O
BC Canada
FYI ,I have also experienced random ticking noise on hemis from rocker arm adjusters hitting the splash shield on the underside of the valve cover as well as exhaust valve springs/retainers just barely hitting the inside of the valve cover
Re: Hemi Valve Adjustment [Re: ogopogo] #1538783
11/25/13 11:30 AM
11/25/13 11:30 AM
Wisconsin
Wisconsin
I see no sign of anything hitting on the valve cover. I have no shield on the inside of my covers other then a small one over the PCV valve hole.
Re: Hemi Valve Adjustment [Re: Mopar_Mudder] #1538784
12/02/13 06:45 PM
12/02/13 06:45 PM
Wisconsin
Wisconsin
Just wanted to update that I got them all adjusted and really it sounds about the same, maybe just the way they sound?
Might be all in my head but it seems to idle a little rougher then it did, but it had been awhile since I had it running so just going off memory.
I ended up tightening all the rockers about 1/4 turn. It does need new plugs but put it away for the winter now.
Re: Hemi Valve Adjustment [Re: Mopar_Mudder] #1538785
12/02/13 07:08 PM
12/02/13 07:08 PM
Nashville, Tennessee
Tempest Online content
Tempest  Online Content
Yes Aluminum heads hot and cold will generally have a significant lash difference. I have to set my solid roller approx .006-.010" tighter to have the hot lash correct.
Re: Hemi Valve Adjustment [Re: Tempest] #1538786
12/03/13 05:05 AM
12/03/13 05:05 AM
Australia
Teamx Offline
Teamx  Offline
Australia
I agree slightly more preload on those big aly heads, my motor grew .009 thou when hot!
