Re: fuel pump? [Re: Mr D21] #1537017
11/20/13 01:30 PM
11/20/13 01:30 PM
68gtx Offline OP
68gtx  Offline OP
I was just trying to find out if they used an adapter or not from the factory. Not trying to make it 100% but close. Thanks larry J
Re: fuel pump? [Re: Mr D21] #1537018
11/20/13 01:59 PM
11/20/13 01:59 PM
Ontario, Canada
FJ5_Fish Offline
FJ5_Fish  Offline
Ontario, Canada
Larry - you have either the wrong pump or the wrong fuel line. Either way, there is NO adapter from the factory.
Sounds like in your case an adapter will be an easy and quick fix if you don't care about factory correctness...
The factory DID use the adapter....they are on all original cars.
Re: fuel pump? [Re: 44D6PAKCUDA] #1537019
11/20/13 03:20 PM
11/20/13 03:20 PM
Ontario, Canada
FJ5_Fish Offline
FJ5_Fish  Offline
Ontario, Canada
hope this helps...
Boy I wold love to see some more photos of that motor...
I could send you some more,but the car is "put away" for the winter.Remind me in the spring and I can send you some additional ones.Those other pictures are from Frank Badalsons display when he had my motor at Carlisle a few years back.
Here is the link... Link
Re: fuel pump? [Re: FJ5_Fish] #1537020
11/20/13 04:23 PM
11/20/13 04:23 PM
68gtx Offline OP
68gtx  Offline OP
Thanks Just so many different opinions on this subject. I wasn't sure if i needed the adapter. It makes since to me that if they used M4845 you need an adapter. Thanks AgainLJ!!!!!!!
Re: fuel pump? [Re: FJ5_Fish] #1537021
11/21/13 03:23 PM
11/21/13 03:23 PM
Washington, MO
hemigeno Offline
hemigeno  Offline
Washington, MO
Restored car, but original fittings and lines:
Re: fuel pump? [Re: hemigeno] #1537022
11/21/13 06:51 PM
11/21/13 06:51 PM
68gtx Offline OP
68gtx  Offline OP
1 adapter coming up!!!!!!!!Thanks lj
