Re: Picking up some W-2's today, going full-circle
[Re: Blucuda413]
#1534059
11/17/13 12:15 AM
11/17/13 12:15 AM
Posts: 251 Saskatchewan (SK)
79410aspenrt
Saskatchewan (SK)
Streetwize, please keep us informed how the W2's work on 440 ci. There has been much discussion on this forum stating that they're too small. I'm seriously considering the same thing which would be 449ci with a good set of W2's. I have a Procharger I'm considering sticking on it also. Keep us posted!!!!!
they will work great. they are not to small. mine is a tad smaller at 436''.
[Re: Streetwize]
#1534064
11/17/13 03:41 AM
11/17/13 03:41 AM
Posts: 2,128 sweden
sshemi
sweden
[Re: Streetwize]
#1534065
11/17/13 03:46 AM
11/17/13 03:46 AM
Posts: 413 Norway (old world)
Oyvind Mopar
Norway (old world)
Scott
Not sure yet but the plan is with the 4.25" crank having 2" sbc journals and using a 6.200 rod that's going to allow me to use a super light 1.26 CH SBC (for a 350 SBC with a 6" rod) Icon race piston and pin and we'll just flycut the valve reliefs for the Mopar valves
I figure the Bobweight should be sub 1800 grams or right at it, a good bit lighter than most 408-416's wind up with 1.47 ish CH.
If you order the pistons for an 18 degree sbc the valve notches will be close to perfect. My
[Re: sshemi]
#1534066
11/17/13 09:07 AM
11/17/13 09:07 AM
Posts: 11,179 Atco NJ
DJVCuda
Atco NJ
My 408 was 1800.
My 430 with BPE 4.125 crank - compstar 6.200 rods and longer CH piston was 1749 grams
[Re: DJVCuda]
#1534067
11/17/13 09:54 AM
11/17/13 09:54 AM
Posts: 1,927 Seaford, Va
Kindafast
Seaford, Va
Hey Wize , what happend to those heads you were testing a while back ?? I haven't been on here in a while. Did they ever work out on your rocky ??
6.50 @105.26
[Re: DJVCuda]
#1534068
11/17/13 09:56 AM
11/17/13 09:56 AM
Posts: 9,881 Weddington, N.C.
Streetwize
Weddington, N.C.
Yes sub 1800 maybe closer to 1700 and 1800 is right around where most 408-416's wind-up (as is mine at 1804), but how much lighter I'm not sure yet but I know those Icon slugs are very light compared to the standard 4" mopar stroker slugs and the ch is ideal, so why not figure out a way to use them?
By super light I was really thinking more to next to a comparable 440 cube big block.
[Re: Streetwize]
#1534069
11/17/13 10:58 AM
11/17/13 10:58 AM
79410aspenrt
Saskatchewan (SK)
my 436'' with Molnar 4.125'' crank, callies 6.200 rods, diamond pistons is 1766 grams
[Re: Streetwize]
#1534071
11/17/13 12:54 PM
11/17/13 12:54 PM
Streetwize
Weddington, N.C.
79410, yeah that's why I'm thinking around 1700. the skirt design of tht SBC ICON race piston is very similar to the SRP, My Machinist Hollis page thinks we can make them work and the bob will come up really light. The BPE 4.25 crank also has the smaller 2" journals so the rod throws themselves will be just a tad lighter as well.
The new LS style pistons are sub 400 grams for a 4.00-4.06 bore.
[Re: W5DART66]
#1534073
11/17/13 01:26 PM
11/17/13 01:26 PM
Streetwize
Weddington, N.C.
Thanks! I think a good 2.08 incher with an 11/32 stem would work great for what I'm planning. I've seen 2.12"s going in W2's back in the 80's but that may have been coupled with a 1.56" exhaust valve (and maybe a bit of fancy offset guide work) but I know it has been done before. I know I'll be swapping out the Cam Motion 261/266 @.050 Mild Endurance ramp roller out of the 414 and into this one since it's a very streetable ramp, with the 1.6:1 rockers it will be .628/.604 lift, should be fun. Oh and the Street Dommy intake DOES look identical internally to the Strip Dommy, I think I remember how to coax a few more ponies out of them. Not as much meat to work with as you have with a Vic but it will serve my purpose fine. I got to admit that the angle milling to get the valves to 16 degrees and getting a quench pad in the same motion has got me thinking. I gave $850.00 for the 2 bare heads, A full set of offset intake roller rockers, billet shaft blocks/hold downs and the intake, not too bad a deal I reckon. Here's a pic
[Re: Streetwize]
#1534078
11/18/13 04:03 PM
11/18/13 04:03 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
I think Holley made a "pro dominator" W2 Tunnel Ram, wonder how hard one of those would be to find?
I have a brand new one at the shop if interested.
RIP Monte Smith
