84 Ram Trim, what is it made of?
#1532741
11/12/13 08:37 PM
11/12/13 08:37 PM
Posts: 1,377 Tennessee
WyleECoyote
Tennessee
What type of metal is the side trim and tailgate trim on 84 trucks? Anyone recommend a polish for using while the trim is still attached? Thanks. Doolie by jimbeameod, on Flickr Dodge Tailgate by jimbeameod, on Flickr
Wile E. Coyote Super Genius, Lover of FCA US LLC Products ************* 68 Road Runner (440 4-spd), 71 Superbee (383 slap), 71 Charger 500 (383 4-spd wA/C 1of 182), 72 Imperial, 74 Charger SE (440 sunroof), 84 D350 Crew-cab Dually (440), 75 D300 Dually Tandem (318 4-speed)
Re: 84 Ram Trim, what is it made of?
[Re: 340SHORTY]
#1532745
11/12/13 09:40 PM
11/12/13 09:40 PM
Posts: 6,048 Back home in PA
BulletBob
Back home in PA
Anodizes aluminum
Anodized aluminimum...
I knew my spellcheck was turned off
[Re: BulletBob]
#1532747
11/14/13 12:41 AM
11/14/13 12:41 AM
Posts: 12,043 State of Confusion
hp383
Just a normal tag again
State of Confusion
If the clear anodizing has turned cloudy, there isn't much you can do with it except maybe strip it, polish the aluminum, and have it recoated.
I tried like heck to shine up a 78 Dodge truck grille and nothing would bring it back without stripping the anodizing.
Join the Penguin Liberation Front!! Stop the Hippo Occupation!
[Re: hp383]
#1532748
11/14/13 10:51 AM
11/14/13 10:51 AM
Posts: 3,325 Truckville, the capital of NY
85_Ram_4speed
And to that, easy off oven cleaner in the yellow can, can be used to strip the old stuff off. Usually takes a few applications. Then the polishing can begin.
Also, that coating really helps protect against normal road debris. I spent alot of time stripping and polising the grill trim on my Dart and very shortly after, I had little tiny dig marks in it--esentially rock chips. It still looked way better than it was before, but you could not run a smooth polish cloth over it without it snagging a burr.
Outcast Dodge guy.
