84 Ram Trim, what is it made of? #1532741
11/12/13 08:37 PM
11/12/13 08:37 PM
Tennessee
WyleECoyote Offline OP
Tennessee
What type of metal is the side trim and tailgate trim on 84 trucks? Anyone recommend a polish for using while the trim is still attached? Thanks.
Doolie by jimbeameod, on Flickr
Dodge Tailgate by jimbeameod, on Flickr
Wile E. Coyote
Super Genius, Lover of FCA US LLC Products
68 Road Runner (440 4-spd), 71 Superbee (383 slap), 71 Charger 500 (383 4-spd wA/C 1of 182), 72 Imperial, 74 Charger SE (440 sunroof), 84 D350 Crew-cab Dually (440), 75 D300 Dually Tandem (318 4-speed)
Re: 84 Ram Trim, what is it made of? [Re: WyleECoyote] #1532742
11/12/13 08:47 PM
11/12/13 08:47 PM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
Anodizes aluminum
Re: 84 Ram Trim, what is it made of? [Re: BulletBob] #1532743
11/12/13 09:13 PM
11/12/13 09:13 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
Anodizes aluminum
Anodized aluminimum...
I am truckless..
Re: 84 Ram Trim, what is it made of? [Re: 340SHORTY] #1532744
11/12/13 09:38 PM
11/12/13 09:38 PM
Tennessee
Tennessee
So is there any cleaning it or polishing it? Or does one just live with it all-naturell....?
Re: 84 Ram Trim, what is it made of? [Re: 340SHORTY] #1532745
11/12/13 09:40 PM
11/12/13 09:40 PM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
Anodizes aluminum
I knew my spellcheck was turned off
Re: 84 Ram Trim, what is it made of? [Re: WyleECoyote] #1532746
11/12/13 09:48 PM
11/12/13 09:48 PM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
I buff the good & find more good buff it & replace the bad
I got lucky at P&P & got trim from a truck someone must have used NOS trim in the resto.
If you look at enough trucks you'll find what you need if needed
Re: 84 Ram Trim, what is it made of? [Re: BulletBob] #1532747
11/14/13 12:41 AM
11/14/13 12:41 AM
State of Confusion
hp383 Offline
Just a normal tag again
hp383  Offline
State of Confusion
If the clear anodizing has turned cloudy, there isn't much you can do with it except maybe strip it, polish the aluminum, and have it recoated.
I tried like heck to shine up a 78 Dodge truck grille and nothing would bring it back without stripping the anodizing.
Join the Penguin Liberation Front!!
Stop the Hippo Occupation!
Re: 84 Ram Trim, what is it made of? [Re: hp383] #1532748
11/14/13 10:51 AM
11/14/13 10:51 AM
Truckville, the capital of NY
85_Ram_4speed Offline
And to that, easy off oven cleaner in the yellow can, can be used to strip the old stuff off. Usually takes a few applications. Then the polishing can begin.
Also, that coating really helps protect against normal road debris. I spent alot of time stripping and polising the grill trim on my Dart and very shortly after, I had little tiny dig marks in it--esentially rock chips. It still looked way better than it was before, but you could not run a smooth polish cloth over it without it snagging a burr.
Outcast Dodge guy.
