Quick times=broken parts for me #1532722
11/12/13 08:29 PM
11/12/13 08:29 PM
Lubbock,TX
DavidDean Offline OP
Lubbock,TX
I've just finishing fixing my broken stuff. A couple of weeks ago I headed to Dallas Raceway for the Door Car Only race.I was excited, the first TT netted a new best of 5.66 @ 120.5. The car lived up to its Thrill Ride name with a big wheelie and a 1.241 60'. The fun ended though as I attempted to qualify for the quick 16 on the next pass. When the car launched it wiped out more than 1/3 of the teeth on my super beefy 8 3/4.It had maybe 75? passes on that R & P. I figured the sprag was also shot. When I pulled my 904 I also found it had broken the input shaft as well as laying over the sprag.Alot of work later and I hope to make the leftover nationals race at Abilene after thanks giving.It's obviously time to retire the 8 3/4 and possibly put in a glide.
I've also considered building a new 904 w/ a Protrans 2.28 low gear to try to calm the car down some more. I've got a lot invested in 904 junk.
Re: Quick times=broken parts for me [Re: DavidDean] #1532723
11/12/13 09:04 PM
11/12/13 09:04 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
Engine fluids containment system...any build pics & pointers??
If you like drag racing, support your local track.
Re: Quick times=broken parts for me [Re: CHAPPER] #1532724
11/12/13 11:27 PM
11/12/13 11:27 PM
Abilene,Texas
ram87 Offline
ram87  Offline
Abilene,Texas
Might be time for a glide. I try to drag my tired old rear out to see you after Thanksgiving. I am working for Lowe's and never know my work schedule until the week before.
Re: Quick times=broken parts for me [Re: DavidDean] #1532725
11/12/13 11:50 PM
11/12/13 11:50 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
was that a stock input or an after market one and do you think the rear end had some thing to do with it braking
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: Quick times=broken parts for me [Re: DavidDean] #1532726
11/13/13 09:00 AM
11/13/13 09:00 AM
Mo.
racerx Offline
racerx  Offline
Mo.
Who's r&p u runing(ratio),was this with a stock housing w/bracing..Thax
Re: Quick times=broken parts for me [Re: WHITEDART] #1532727
11/13/13 10:22 AM
11/13/13 10:22 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
absolutely the rear braking had something to do with the input shaft breaking. Same shock on the system is what also kills the sprag. I was surprised to see David's car still running the 8.75 when I saw it at Vegas.
Re: Quick times=broken parts for me [Re: J_BODY] #1532728
11/13/13 12:26 PM
11/13/13 12:26 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
I'm definitely not trying to be a smart a** here but an 8-3/4 in a 5 second car? A 904 in a 5 second car? You know better than to try that. God created Danas for a reason.
2011 Drag Pak Challenger
Re: Quick times=broken parts for me [Re: racerx] #1532729
11/13/13 12:32 PM
11/13/13 12:32 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I'm sure it has all the tricks applied to the housing but in the end the weak link is the ring and pinion teeth, you can strengthen everything else it's still going to rip the teeth off those 2 gears at some point.
Re: Quick times=broken parts for me [Re: J_BODY] #1532730
11/13/13 12:42 PM
11/13/13 12:42 PM
Lubbock,TX
Lubbock,TX
Here's a pic of the belly pan. Most people on this site seem to favor a diaper. I like the pan its easier to fit, make and maintain the engine. A number of my top sportsman friends also use a simular pan. It follows the NHRA guidelines frame rail to frame rail trans housing to infront of the balancer. It has a screen in the bottom to hold the same pad as in a Jegs diaper. 2" + tall on the sides. My Bob's Profab K member made the installation possible.I just kept making cardboard patterns untill I had something that would work. My local chassis guy (Mike Carpenter)gave me lots of pointers and welded up the final design.
Hey Lynn it would be great to see ya there!
The input shaft was stock and so was the replacement I hope it'll stand up for a while.I would agree the rear breaking led to the input shaft breaking.
The R&P was and is 3.91 ratio. I shift this motor about 6800 rpm. The rear has all the tricks you can have in an 8 3/4. Billet caps, back braced gusseted outside as well as inside. It's not an alunimium housing though. I looking at a dana 60 as a replacement.
I'm trying to decide between a glide and and up dating my 904 w/ 2.28 1st gear. My 904 has some fairly nice stuff inside and its pretty fast.
Re: Quick times=broken parts for me [Re: DavidDean] #1532731
11/13/13 01:30 PM
11/13/13 01:30 PM
SoCal
Brian Hafliger Offline
SoCal
David did you end up changing the block or ???
Brian Hafliger
Re: Quick times=broken parts for me [Re: Brian Hafliger] #1532732
11/13/13 01:56 PM
11/13/13 01:56 PM
Lubbock,TX
Lubbock,TX
I had Sunset repair the block and Ive routed water to the back of the heads and changed the tune up a little .So far so good
Re: Quick times=broken parts for me [Re: DavidDean] #1532733
11/13/13 02:11 PM
11/13/13 02:11 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
thanks.
