Re: Quick times=broken parts for me
[Re: WHITEDART]
#1532727
11/13/13 10:22 AM
11/13/13 10:22 AM
Posts: 13,200 aZLiViN
J_BODY
aZLiViN
was that a stock input or an after market one and do you think the rear end had some thing to do with it braking
absolutely the rear braking had something to do with the input shaft breaking. Same shock on the system is what also kills the sprag. I was surprised to see David's car still running the 8.75 when I saw it at Vegas.
[Re: J_BODY]
#1532728
11/13/13 12:26 PM
11/13/13 12:26 PM
Posts: 2,652 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
I'm definitely not trying to be a smart a** here but an 8-3/4 in a 5 second car? A 904 in a 5 second car? You know better than to try that. God created Danas for a reason.
2011 Drag Pak Challenger
[Re: racerx]
#1532729
11/13/13 12:32 PM
11/13/13 12:32 PM
Posts: 75,050 U.S.S.A.
JohnRR
U.S.S.A.
Who's r&p u runing(ratio),was this with a stock housing w/bracing..Thax
I'm sure it has all the tricks applied to the housing but in the end the weak link is the ring and pinion teeth, you can strengthen everything else it's still going to rip the teeth off those 2 gears at some point.
[Re: J_BODY]
#1532730
11/13/13 12:42 PM
11/13/13 12:42 PM
Posts: 1,632 Lubbock,TX
DavidDean
Lubbock,TX
Here's a pic of the belly pan. Most people on this site seem to favor a diaper. I like the pan its easier to fit, make and maintain the engine. A number of my top sportsman friends also use a simular pan. It follows the NHRA guidelines frame rail to frame rail trans housing to infront of the balancer. It has a screen in the bottom to hold the same pad as in a Jegs diaper. 2" + tall on the sides. My Bob's Profab K member made the installation possible.I just kept making cardboard patterns untill I had something that would work. My local chassis guy (Mike Carpenter)gave me lots of pointers and welded up the final design. Hey Lynn it would be great to see ya there! The input shaft was stock and so was the replacement I hope it'll stand up for a while.I would agree the rear breaking led to the input shaft breaking. The R&P was and is 3.91 ratio. I shift this motor about 6800 rpm. The rear has all the tricks you can have in an 8 3/4. Billet caps, back braced gusseted outside as well as inside. It's not an alunimium housing though. I looking at a dana 60 as a replacement. I'm trying to decide between a glide and and up dating my 904 w/ 2.28 1st gear. My 904 has some fairly nice stuff inside and its pretty fast. Hey Lynn it would be great to see ya there!
[Re: DavidDean]
#1532731
11/13/13 01:30 PM
11/13/13 01:30 PM
Posts: 5,486 SoCal
Brian Hafliger
SoCal
David did you end up changing the block or ???
Brian Hafliger
