Page 1 of 3 1 2 3
Cost to paint a car? #1532395
11/11/13 10:44 PM
11/11/13 10:44 PM
Northern NJ
68 Sat Offline OP
68 Sat  Offline OP
Northern NJ
I have a 69 B Body that I am thinking of changing color from yellow to red. Assuming bodywork is minimal how much does this usually run. I am in the North East..
1963 Chrysler 300 Pace Setter Convertible 21K mile survivor 1969 Dodge Coronet 500 1956 Desoto Hemi 1955 Chrysler C300
Re: Cost to paint a car? [Re: 68 Sat] #1532396
11/11/13 10:54 PM
11/11/13 10:54 PM
First off, talk about changing the color of your car at your own risk around here. I was almost virtually castrated for it.
Secondly, paint jobs are very expensive, especially done well. i.e: painting door jambs, underhood, trunk......
There is almost no way to guesstimate what it would cost for you, but I will try. 6-12k depending on how straight you want it and how clean it is to start.
, leave it alone or respray it Y2.
Re: Cost to paint a car? [Re: 68 Sat] #1532397
11/11/13 11:11 PM
11/11/13 11:11 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
That question is so open ended that it can't be answered with an adequate response, are you looking for a "rotisserie" style paint job where the car is as OEM finished, or over restored in finish? ie showcar finish, or a quickie Macco job?...who will disassemble the car for paint?, if that's your intention, if so who will assemble the car after paint?, any frame/floor rust repairs needed?, that you know about?, are you prepared financially for the inevitable when the initial quote is now doubled?....the more info on your paint intentions, the clearer the estimates...
Re: Cost to paint a car? [Re: DAYCLONA] #1532398
11/11/13 11:29 PM
11/11/13 11:29 PM
KY USA
mopargem Offline
mopargem  Offline
KY USA
This car has lasted all these years and you want to color change it ..... Uhg!
68 Polara 500...LL1 Y7 M6X
69 Hemi road runner...X9 X9 M6X
69 A12 road runner....R4 R4 M6X
69 ModTop FLORAL Super Bee...F6 M6W
70 AAR 'cuda...EW1 EW1 H4X9
71 Duster 340...FJ6 V24 L6X9
71 road runner FC7 V1X M6X9
72 Rallye Charger B5 V1W
74 'cuda 360...KB5 V1X A6X9
08 SRT Challenger #234
Re: Cost to paint a car? [Re: mopargem] #1532399
11/12/13 12:10 AM
11/12/13 12:10 AM
Northern NJ
68 Sat Offline OP
68 Sat  Offline OP
Northern NJ
All good questions. The issue is as such: the car was reprinted in the early 80s in single stage. The job was ok and is starting to breakdown. The car either needs a repaint or I need to leave it alone I could dis-assemble as well as re-assemble to a certain point. Would probably need assistance on some of it. The car is in relatively good shape and would probably need minor rust/metal repair. I am trying to figure out whether its worth it to attack this project or just cut my losses and and buy another car. Not looking for concourse but not maaco either. Just a nice driver.
Re: Cost to paint a car? [Re: 68 Sat] #1532400
11/12/13 12:15 AM
11/12/13 12:15 AM
california
Mr D21 Offline
Mr D21  Offline
california
Is this the certain point your referring to? If so, then $7500. And I'm going Acrylic Enamel Single Stage
Re: Cost to paint a car? [Re: 68 Sat] #1532401
11/12/13 12:24 AM
11/12/13 12:24 AM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
Just a nice driver.
If you have no attachment to the car-ship it...
There's a ton of 'nice drivers' out there with a sign in the window...
Re: Cost to paint a car? [Re: RSNOMO] #1532402
11/12/13 12:27 AM
11/12/13 12:27 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
VERY good Idea!
Re: Cost to paint a car? [Re: 68 Sat] #1532403
11/12/13 02:10 AM
11/12/13 02:10 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
then it appears your looking for more of a cosmetic paint job, rather than a full blown resto type refinish, if done "properly", the car needs to be stripped of the old paint, your talking about all the trim removal, possibly the vinyl top dependent on its condition, now your talking a lot of masking/covering if you don't want to remove the interior, glass, etc...the car should be painted in the jambs for a somewhat professional appearance, again a lot of taping/masking/covering if the interior is left intact, as well as underhood,...now add the countless hours of bodywork, blocking, nevermind rust repair if needed...for what will be considered a somewhat half-ar$ed "resto" you'll be dropping a minimum of $5K for a decent paint job, to $10K plus for a "quality" paint job depending on your requirements, and additional work here on the east coast, paint/primer/body materials alone will run the shop anywhere from $2500-$5K...then add the labour!...sure there's plenty of shops out there that will tell you $2K, $3K. $4K for a paint job, you get what you pay for...bodywork and paint is the biggest stumbling block for the auto enthusiast, if you can't perform the work yourself, then your at the mercy of a shop, you cut corners, or they cut corners, you get what you paid for, plus it's harder to find shops that want to do restos, even if it's just "light" work, like a repaint, and if your contemplating a color change, don't half-ar$e it, your basically looking at complete disassembly to properly change the color of the car....this is how "just a repaint", snowballs into a full blown resto, and for some, a project that turns into a multi year project, and a financial nightmare....
Re: Cost to paint a car? [Re: 68 Sat] #1532404
11/12/13 05:49 AM
11/12/13 05:49 AM
Riyadh, Saudi Arabia
Merlin45 Offline
Merlin45  Offline
I just had my 74 Challenger painted, cost was a little over $3900. My car was B5 Blue and I kept it the same color. You can see my car at the web site listed below. The body shop did an excellent job and I'm very pleased. In addition to the paint job I put on a new front clip, had the engine rebuilt (spun a cam bearing), and did many, many corrosion repairs. I very happy with the outcome, in the past when I drove the car I always had people take pictures or video while driving, I see the same problem coming again. You can see the work/progress at:
http://hnhrodshop.com
Re: Cost to paint a car? [Re: Merlin45] #1532405
11/12/13 10:57 AM
11/12/13 10:57 AM
Warren, MI
71TA Offline
71TA  Offline
Warren, MI
NICE CHALLENGER! I've been looking to buy a clean 74 but all the nice ones are 30's to 40's
PS I have a 71 B5 Challenger. I'm saving UP to get a $10,000 paint job. Thats what a decent one costs around here. I BLEW $5000 having a recommended, adult who paints at a company that customizes show cars for the big 3. They ruined the MY CAR. Now it has to be taken apart, stripped and repainted. So sick I'm tempted to part it out. Haven't driven it in 3 years. Point is, don't cut corners and go with HIGHLY RECOMMENDED (by many people) painter.
www.DetroitMuscleTechnologies.com Mopar body and heater box restoration gaskets
Re: Cost to paint a car? [Re: DAYCLONA] #1532406
11/12/13 11:27 AM
11/12/13 11:27 AM
Nashville, TN
MOPARMIKE69 Offline
MOPARMIKE69  Offline
Nashville, TN
EXACTLY!
69 Road Runner vert
69 GTX hard top
70 Road Runner 4 speed
70 Hemi Cuda vert
Re: Cost to paint a car? [Re: Merlin45] #1532407
11/12/13 11:50 AM
11/12/13 11:50 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I don't think you are telling us the whole story? Front clip replacement, rust repair and paint for $3900 bucks?
Re: Cost to paint a car? [Re: MOPARMIKE69] #1532408
11/12/13 11:52 AM
11/12/13 11:52 AM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
time to clean it up and sell...
Re: Cost to paint a car? [Re: RodStRace] #1532409
11/12/13 12:11 PM
11/12/13 12:11 PM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
$45 an hour X x hours plus materials.
Re: Cost to paint a car? [Re: 71TA] #1532410
11/12/13 12:37 PM
11/12/13 12:37 PM
N.E. Ohio
K
KillerBee Offline
KillerBee  Offline
K
N.E. Ohio
When can I come up and pic up the stroker engine and T/A hood.
Re: Cost to paint a car? [Re: MOPARMIKE69] #1532411
11/12/13 01:05 PM
11/12/13 01:05 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
EXACTLY!
x3
repaint it the original color or heed the consequences described above. Around here $10 - $15k or so will get you a decent exterior only paintjob with minimal bodywork required. plan on double those numbers as a starting point if you blow the car apart for a proper color change.
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: Cost to paint a car? [Re: KillerBee] #1532412
11/12/13 01:40 PM
11/12/13 01:40 PM
Warren, MI
71TA Offline
71TA  Offline
Warren, MI
Don't TEMPT me
You know thats and AndyF 470" shortblock from his magazine article "How to get 570HP with exhaust manifolds". Now it has max ported Edelbrock heads from the late Modern Cyl Head with beehive springs and a MP528 mechanical cam.
TA hood - it's one of those GOOD ASC&P repops. Has one hairline crack by the scoop and the screens at the back of the hood have some slight surface rust. If (WHEN) I repaint it would get SS screens.
Just don't EVER see having the time with the gasket biz and another $30K to throw at it. Might be able to get $20k out of it in parts.
Sorry for the hijack
Re: Cost to paint a car? [Re: 68 Sat] #1532413
11/12/13 01:52 PM
11/12/13 01:52 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Thats a beautiful car, I have a 69 4 door that color, and wish it was drivable again. I say leave it. If you just can't stand it, give it to me.
Re: Cost to paint a car? [Re: 68 Sat] #1532414
11/12/13 03:14 PM
11/12/13 03:14 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Around here , I could probably have it painted in the $5K range , depending on metal work / rust repair. And it would be a pretty decent looking car once completed . I have enough friends that are painters I would not have to run it through a shop( except for paint booth rental)
Page 1 of 3 1 2 3
