8 3/4 gear ratio tag
#1531103
11/10/13 02:13 AM
11/10/13 02:13 AM
Posts: 4,437 Omaha Nebraska
Brian_wo
Omaha Nebraska
did all the 8 3/4 rears come with the axle ratio tag? just pulled one off my 67 Belevedere and found that it is a 2.94.
who is that guy?
Re: 8 3/4 gear ratio tag
[Re: Brian_wo]
#1531104
11/10/13 02:32 AM
11/10/13 02:32 AM
RapidRobert
You'd think if Ma did one she'd of done em all but I've sure seen alot without those tags.
[Re: RapidRobert]
#1531105
11/10/13 02:44 AM
11/10/13 02:44 AM
Brian_wo
Omaha Nebraska
me to but then a guy wonders if it was taken off before he got it or did just the rears with suregrips get them or?
who is that guy?
[Re: RapidRobert]
#1531107
11/10/13 12:34 PM
11/10/13 12:34 PM
Posts: 52 Ohio
Super Coupe
Ohio
I've seen a couple with just a thin piece of short metal under a non-SG stud bolt. Like a thin washer. I assumed the tags were long ago broken or simply rusted off.
The name's Bondo. Jams Bondo
Tonight I'm dining with Clia Torrez
[Re: MoparforLife]
#1531109
11/10/13 07:45 PM
11/10/13 07:45 PM
Brian_wo
Omaha Nebraska
Thx,was just wondering(out loud?)
The 67 vert I just finally brought home had the tag and I was sure it was an open diff untill my second burnout where the car lit up both tires and went sideways toward my RR.
who is that guy?
[Re: Brian_wo]
#1531110
11/10/13 07:54 PM
11/10/13 07:54 PM
Posts: 8,682 Buford, GA
I_bleed_MOPAR
Buford, GA
Dads '67 Belvedere II s/w had an open 2.94 w/ the tag on it. I thought the SGs had a paint mark? on the diff plus a separate tag about using the correct lube? Tim
'71 Charger 383/727 '17 Challenger SXT (Wifeys car )
