welding on running car #152988
11/18/08 08:11 PM
11/18/08 08:11 PM
ohio
dodgedart416 Offline OP
ohio
Need to do some welding on my dart. I already disconnected battery is there anything else that needs to be unhooked like ignition, alternator? Thanks
Re: welding on running car [Re: dodgedart416] #152989
11/18/08 08:41 PM
11/18/08 08:41 PM
New Zealand
solidcam Offline
solidcam  Offline
New Zealand
Probably not required but I always remove the MSD grounding wire/s(if you are running one) in addition to disconnecting the battery.
Re: welding on running car [Re: solidcam] #152990
11/18/08 09:16 PM
11/18/08 09:16 PM
keep welder ground close to work.
Re: welding on running car [Re: dodgedart416] #152991
11/18/08 11:18 PM
11/18/08 11:18 PM
Carstairs, Alberta, Canada
dave571 Offline
dave571  Offline
Unplugging the ground is a good precaution.
I often think the fear of wrecked electronic stuff is a little inflated, but it's aleways good to be cautious.
FWIW... I've mig welded leaking exhaust pipes on running cars(while they were actually running) next to the o2 sensor without issue.
Re: welding on running car [Re: dave571] #152992
11/18/08 11:20 PM
11/18/08 11:20 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
Yep, exhaust shops work on cars day in and day out without disconnecting anything
Re: welding on running car #152993
11/18/08 11:26 PM
11/18/08 11:26 PM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
Clean your ground clamp of any corrosion if its been sitting for a while.
Re: welding on running car [Re: 69Cuda340S] #152994
11/19/08 02:15 PM
11/19/08 02:15 PM
ky.
K
kenworth_goose Offline
K
ky.
I weld all over the place on old and new cars, trucks and have never heart anything. It's just a myth.
Re: welding on running car [Re: kenworth_goose] #152995
11/19/08 02:39 PM
11/19/08 02:39 PM
White Plains, NY
VCODE Offline
VCODE  Offline
White Plains, NY
Not to but my welder at work was welding a bracket on a tow truck boom and the steel braided hyd lines went on fire which made them leak
Bob
Mom & Dad let me buy a brand new 70 Challenger R/T 440 Six-Pack Super Trac Pack when I was 17
(Robert what is a 440 Six-Pack)
Re: welding on running car [Re: VCODE] #152996
11/19/08 03:00 PM
11/19/08 03:00 PM
Omaha, Nebraska
Scott Carl Offline
Scott Carl  Offline
Omaha, Nebraska
If the bracket was on the boom and the ground was on the truck, there may have been enough grease in the boom's pivot to make the ground decide to use the nice clean hyd lines rather than the boom for a path. Electricity doesn't neccesarily take the shortest but rather, the easiest path to ground.
Re: welding on running car #152997
11/19/08 03:43 PM
11/19/08 03:43 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
Re: welding on running car [Re: kenworth_goose] #152998
11/19/08 06:54 PM
11/19/08 06:54 PM
Seminole County FL to Plymouth...
Barry70GTX Offline
Barry70GTX  Offline
Sooner or later you will be buying a computer for one of those late model cars if you don't disable them before welding.
I lost one in a Nissan that cost me $800 to replace.Not nearly as bad as the one my buddy toasted in a Ferrari.
NMCA NSS 67 Coronet
