Undercoat last thing??
#1528884
11/05/13 10:39 AM
11/05/13 10:39 AM
Posts: 222 Canfield,Ohio,USA
gassy66
Canfield,Ohio,USA
Build sheet on My St.Louis built '67 GTX indicated Car had shoulder belts,and also undercoat. I now have shoulder belts,and installation instructions which show anchoring of Belts with large washer and bolt thru rear wheel housing into eyelet. I'm assuming undercoat would be last, and applied over washer and bolt head ??
Re: Undercoat last thing??
[Re: gassy66]
#1528885
11/05/13 11:38 AM
11/05/13 11:38 AM
Posts: 18,157 Mass
DAYCLONA
Mass
Nothing written in stone when it comes to plant by plant procedures, vehicle lines, etc, etc, but usually bolts that were exposed to undercoating generally had a swat of masking tape applied to the bolt head, then undercoated....best to duplicate what WAS present on YOUR car, if you know, if not, there's many different interpertations, I'm sure others will post there findings
mike
[Re: gassy66]
#1528888
11/06/13 05:57 PM
11/06/13 05:57 PM
Posts: 1,822 Colorado
denfireguy
Colorado
Keep in mind that in that era, dealerships would upsell the buyer on additional undercoating that would obviously go on after the factory was done with the car. They had not invented the additional warranty thing yet.
Craig
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
