Recommenfations on torsion bars and shocks please
#1528356
11/04/13 12:14 AM
11/04/13 12:14 AM
Posts: 469 Hawaii
Dodgeballs
Hawaii
I don't want to spend a bunch of money now, so I would like to build around what I have now.
1969 Dart 340 4 spd. 3.91 Oval track leafs 245/60/14 back 215/70/14 front
I was thinking of addco sway bars because of price. 1 1/8" fronts 3/4 or 7/8" rear?
What size torsion bars should I use? A decent cheaper shock (but if bilsteins are a lot better for a couple hundred more, I guess I can go that way)?
I just rebuilt the front end. What camber/caster/toe settings? The car is not a daily driver. It doesn't go far - I'm in Hawaii. I don't mind a little more aggressive camber setting, I think.
Thanks for any suggestions.
Re: Recommenfations on torsion bars and shocks please
[Re: Dodgeballs]
#1528358
11/04/13 03:55 PM
11/04/13 03:55 PM
Posts: 1,442 NW Chicago suburban area
Mopar Mitch
Regarding TBs... for your a-body.. don't be afriad of stiffer rated bars.. i know a few guys running the 1.14s on the street for A-bodies.. not bad at all and they wouldn't hesitate to install 1.18 if they really wanted to... and you would not regret it.. in fact, it'll end up being a new base for the best suspension mod you'll make.. and remember to keep it an overall "package" (TBs, leafs, shocks, sway bars, bushings... your tires are pretty small, especially in the front.. consider other sizes as well as rims.
Mopar Mitch
"Road racers and autocrossers go in deeper and come out harder!"... and rain never stops us from having fun with our cars... in fact, it makes us better drivers!
Check out MOPAR ACTION MAGAZINE, August 2006 issue for feature article and specs on my autocross T/A!
[Re: jcc]
#1528360
11/04/13 04:45 PM
11/04/13 04:45 PM
Posts: 469 Hawaii
Dodgeballs
Hawaii
So in on the island you must always be turning?
90% of what you are seeking has been covered in other threads here, they are worth reviewing, my only initial comment I'd make, and there are differing opinions on this solution, is only consider the rear bar after everything else is sorted out, and then decide.
Yeah - it's like a big NASCAR track...
The reason I ask is because I have no idea about setting up a suspension for turns. And I've looked through past threads, but I don't see anything with my setup. I've read some KYB vs Bilstein stuff. I'm not afraid of a stiff setup with the torsion bars, per se. I was wondering what size torsion bars would work best with the Oval Track springs I have... I think I'd like the car to have slight oversteer.
I've had some bad oversteer cars - no fun. The best feeling car I ever had was a stock '78 firebird. You could hit a turn way too fast and it never spun - just kicked the back out a bit and waited for the tires to catch up and get some traction (a piece of junk car otherwise).
Do you guys really think no rear sway bar? Or the small one?
[Re: 72Swinger]
#1528361
11/04/13 04:48 PM
11/04/13 04:48 PM
Posts: 469 Hawaii
Dodgeballs
Hawaii
As much as I hate too, I agree with jcc on this. I have a rear bar sitting in the corner of my garage because of this. The rear bar made the car ride rougher and a contender for a drifting trophy.
Do you mean it made the car way too loose? I don't mind the rough ride. This thing is gonna be pounded and I don't need a Cadillac smooth ride. I don't want it to spin like a top either, though.
[Re: Mopar Mitch]
#1528362
11/04/13 04:54 PM
11/04/13 04:54 PM
Posts: 469 Hawaii
Dodgeballs
Hawaii
I will change the tires/rims eventually. But they are brand new and (long story) I had to go with what I got right now. I guess I prefer matching the TB's/leafs/shocks to themselves above anything else, since the tires will change eventually. I have poly strut bushings, rubber LCA, and moog k7103 offset uppers.
So I guess to start - what size T-bars would best match the oval track leafs?
[Re: Supercuda]
#1528364
11/04/13 08:09 PM
11/04/13 08:09 PM
Posts: 469 Hawaii
Dodgeballs
Hawaii
That depends, what are your corner weights and what is the spring rate of the leafs?
For my 65 Cuda, which isn't all that applicable to you, .89" bars matched the oval track leafs I bought.
I really don't know my corner weights. I don't know if I have access to scales to figure that out. I figured someone with a dart would have a good idea of what to go with.
The spring rates are 120 lbs/inch.
[Re: Dodgeballs]
#1528365
11/04/13 09:15 PM
11/04/13 09:15 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Weight has a prime effect on good handling. With AC, without, battery relocated, any weights removed or relocated. It all plays into the effect. Front to rear ratios are important too.
Most of the posters here are into a lot more than just a better handler on the street, sorta semi serious about it actually.
You may want to narrow the options down for us otherwise you are gonna get a bunch of high dollar suggestions. You got a budget?
[Re: 72Swinger]
#1528367
11/04/13 10:19 PM
11/04/13 10:19 PM
Posts: 4,395 The Pale Blue Dot
Skeptic
The Pale Blue Dot
https://board.moparts.org/ubbthreads/show...e=0#Post7909560
A very relavant thread. I'd recommend Andy F's Torsion Bar Tango as a place to read. As you can guess, what is best is quite different from one person to the next. My cars first upgrade was to the MP .920" bars, Addco 1" front/ 3/4" rear bars and Edelbrock IAC shocks. It made for a good riding combo that I could comfortably take freeway on/off ramps at 2X the posted limits. I'm getting more aggressive with the parts and adding a bigger engine with easily 2X the HP of the tired 318 that was in there before.
[Re: Skeptic]
#1528368
11/04/13 11:45 PM
11/04/13 11:45 PM
Posts: 469 Hawaii
Dodgeballs
Hawaii
I did read that thread. And that article by AndyF was very informative. Thanks.
Maybe I'll try the 1.03", KYB's, 1 1/8, 3/4 sway bars - see what happens.
[Re: Supercuda]
#1528369
11/05/13 12:21 AM
11/05/13 12:21 AM
Posts: 469 Hawaii
Dodgeballs
Hawaii
I do have a limited budget. That's why I was wanted to figure out something budget that would work together based on what I already have. I have a Roadrunner that I will go full Hotchkiss. But for the Dart, I don't want to put a lot of money towards it right now. I will do some homemade frame connectors. I rebuilt the front. I'm pretty much looking at cheap sway bars and torsion bars to match my oval track leafs. And I guess it's KYB's or Bilsteins. I was looking for something that would handle decent and be balanced within those limitations. I will do wheels and tires - later.
[Re: Dodgeballs]
#1528371
11/05/13 04:33 PM
11/05/13 04:33 PM
Posts: 411 Texas
vynn3
Texas
After I went from KYB's to Bilstein's, and I'd never buy KYB's again. Bilstein's had better comfort AND handling/control with the 1.03" bars. Bigger torsion bars MUST have better shocks to enjoy the full benefits. I'd read this over and over, but didn't fully believe until I tried it.
vm
[Re: Dodgeballs]
#1528372
11/05/13 09:54 PM
11/05/13 09:54 PM
Posts: 380 Escondido CA USA
Tomswheels
Escondido CA USA
From my personal autocross experience, I would highly recommend the 1.06' with Hotchkis shocks and the biggest front bar you can find. My 69 Barracuda handled much worse with a rear bar! I guarantee the money you would waste on a rear bar is much better spent on upgrading to Hotchkis shocks...
[Re: Tomswheels]
#1528373
11/05/13 10:14 PM
11/05/13 10:14 PM
Supercuda
About to go away
About to go away
up yours
Gee, wonder why a rear bar was a problem?
[Re: Supercuda]
#1528375
11/07/13 01:13 AM
11/07/13 01:13 AM
Tomswheels
Escondido CA USA
I believe when you stop the rear from leaning, you stop what little weight is in the rear from transferring to the outside tire. The rear stepped out much earlier with the rear bar.
