body plug location #1528293
11/03/13 09:16 PM
11/03/13 09:16 PM
KY
70cudaMD Offline OP
70cudaMD  Offline OP
KY
Plug kit has some rubber plugs and some plastic. Have pics of finished trunks but can't tell from pics were plastic plugs go. Thanks.
Re: body plug location [Re: 70cudaMD] #1528294
11/04/13 11:05 PM
11/04/13 11:05 PM
KY
70cudaMD Offline OP
70cudaMD  Offline OP
KY
just need to know if the plastic plugs are for the trunk or floor pans. Or are they just ramdom. Thanks.
Re: body plug location [Re: 70cudaMD] #1528295
11/05/13 10:49 PM
11/05/13 10:49 PM
Wisconsin
Mopar Mark Offline
Mopar Mark  Offline
Wisconsin
I couldn't find anything in a search, but there is a factory drawing for this somewhere on this site.
1970 Challenger R/T 440-4 Auto 2000 Ram Quad Cab 4x4 360 Auto 1973 Dodge 1/2 ton 4x4 318 Auto 1995 Dodge Dakota 4x4 318 Auto
Re: body plug location [Re: Mopar Mark] #1528296
11/05/13 11:26 PM
11/05/13 11:26 PM
KY
70cudaMD Offline OP
70cudaMD  Offline OP
KY
thanks
Re: body plug location [Re: 70cudaMD] #1528297
11/07/13 09:56 PM
11/07/13 09:56 PM
Tucson, AZ
cruzin Offline
cruzin  Offline
Tucson, AZ
70cudaMD,
What car?
Looking at your handle, on an E-body, the body plug found for the rear inner quarter panel, uses a plastic plug. There's a flat portion of the plug and it has a built in weep hole. Perhaps this is the plug you are describing?
Do you have a picture?
Re: body plug location [Re: cruzin] #1528298
11/07/13 10:32 PM
11/07/13 10:32 PM
KY
70cudaMD Offline OP
70cudaMD  Offline OP
KY
Yes for a 70 CUDA. Buddy of mines charger has plastic plugs in the trunk so he thought all the trunk plugs should be plastic. Just not sure because plug kits have plastic and rubber plugs. And I was wondering about the plug with hump in it. Thanks.
Re: body plug location [Re: 70cudaMD] #1528299
11/07/13 11:20 PM
11/07/13 11:20 PM
Tucson, AZ
cruzin Offline
cruzin  Offline
Tucson, AZ
These are what I'm describing.
Re: body plug location [Re: cruzin] #1528300
11/08/13 08:12 AM
11/08/13 08:12 AM
Ky
jt4406 Offline
jt4406  Offline
Ky
Plug goes inside bottom of rear quarter, just behind wheel.
jess
Yeah, it's hopped up to over 160...
Re: body plug location [Re: jt4406] #1528301
11/08/13 08:18 AM
11/08/13 08:18 AM
Ky
jt4406 Offline
jt4406  Offline
Ky
holes in trunk floor...
Re: body plug location [Re: jt4406] #1528302
11/08/13 04:01 PM
11/08/13 04:01 PM
Warren, MI
71TA Offline
71TA  Offline
Warren, MI
Whats the difference between the black and gray qtr drain plugs (other than THE COLOR)?
www.DetroitMuscleTechnologies.com Mopar body and heater box restoration gaskets
Re: body plug location [Re: 71TA] #1528303
11/08/13 04:12 PM
11/08/13 04:12 PM
eastern, pa.
cudabitten Offline
cudabitten  Offline
eastern, pa.
I have one of each. I cant see a difference. The original one on my cuda is black. I bought a repro that is gray. FYI, I'm going to rtv mine in place they do not seem to fit tight into the AMD drop-offs.
Re: body plug location [Re: cudabitten] #1528304
11/08/13 05:25 PM
11/08/13 05:25 PM
Back In Iowa
belv2vert66 Offline
belv2vert66  Offline
Back In Iowa
Not to Hijack but does anyone know if there is a drawing like the one above for a 68 B body ?
Re: body plug location [Re: 70cudaMD] #1528305
11/12/13 11:02 AM
11/12/13 11:02 AM
pa.
dan9 Offline
dan9  Offline
pa.
I saw a Challenger for sale on ebay that was original. They had it on a rack to show what it looked like underneath. I can tell where most of them go by looking at their pics. Some of the plastic and rubber plugs are the same size. You can tell where the rubber plugs are by the amount of material showing, there was more mass to the rubber ones. Right or wrong I'm going to put mine in the way that supposed original car has them. I think they omit provisions for plugs in some repro parts.
