Aftermarket Race B/RB Block Question...... #1527405
11/02/13 12:34 PM
11/02/13 12:34 PM
Holly/MI
Dean_Kuzluzski Offline OP
Holly/MI
So I got an aftermarket oilpan for a GenII Hemi (RB) based with the typical flat mounting surface to the underside of the block. Tried to mock it up and it is totally too big to even mate up. This thing is made for something with a much wider crankcase.
Just looking for any info so I can properly describe what it is or know its useage????
This is not a thinly disguised for sale ad..... I have no idea what it would mate up to. I'm thinking Keith Black Hemi?
Dean
Re: Aftermarket Race B/RB Block Question...... [Re: Dean_Kuzluzski] #1527406
11/02/13 12:47 PM
11/02/13 12:47 PM
CLARKSVILLE,TN.
DAYTONA540 Offline
DAYTONA540  Offline
CLARKSVILLE,TN.
It's probaly for a wide space block. I think most top fuel use a wide space pan and indy offers a wide space block option on there alum. block.Hope this helps.
Re: Aftermarket Race B/RB Block Question...... [Re: DAYTONA540] #1527407
11/02/13 01:58 PM
11/02/13 01:58 PM
Alberta Canada
E
Edge Offline
Edge  Offline
E
Alberta Canada
If it is an aluminum block with wider pan rail it is quite likely a TFX block, also check lifter bore and main bearing diameter. If it was an older fuel block likely to have 1 inch lifter bores and 3 inch mains ) this configuration was quote common for fuel blocks post up a picture and can tell for sure
76 Duster work in progress
Re: Aftermarket Race B/RB Block Question...... [Re: Dean_Kuzluzski] #1527408
11/02/13 02:00 PM
11/02/13 02:00 PM
Franklin, TN
23T Hemmee Offline
23T Hemmee  Offline
Franklin, TN
Most likely a TFX pan if it's that much wider. The KB blocks which are no longer legal for T/F still use the stock pattern as do the BAE billet T/F blocks. It would make sense for Indy to use the TFX pattern for their wide pan blocks but they may make their own pan.
Ronny
6.789 @ 198.63 **.956 Brand New 60'***
4.17@ 169 1/8th mile
John 14:6
https://www.youtube.com/watch?v=TUku_hjYRh8
Re: Aftermarket Race B/RB Block Question...... [Re: 23T Hemmee] #1527409
11/02/13 06:22 PM
11/02/13 06:22 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
my Indy Maxx block is double drilled for stock sized & a wider version on the oil pan.
Re: Aftermarket Race B/RB Block Question...... [Re: 23T Hemmee] #1527410
11/03/13 03:19 PM
11/03/13 03:19 PM
Holly/MI
Holly/MI
OK, thanks guys!!
It is that much wider. I've considered making an adapter plate to use it but that is yet to be seen.
Re: Aftermarket Race B/RB Block Question...... [Re: Dean_Kuzluzski] #1527411
11/03/13 03:23 PM
11/03/13 03:23 PM
Alberta Canada
E
Edge Offline
Edge  Offline
E
Alberta Canada
if it is a TFX block they make a specific pan for them also you will need a TFX specific gear drive as well
Re: Aftermarket Race B/RB Block Question...... [Re: Edge] #1527412
11/03/13 07:12 PM
11/03/13 07:12 PM
Sidney,Ohio
challenger1320 Offline
Sidney,Ohio
Reread the post. He has an oil pan not a block
