Aftermarket Race B/RB Block Question......
#1527405
11/02/13 12:34 PM
11/02/13 12:34 PM
Posts: 8,940 Holly/MI
Dean_Kuzluzski
Holly/MI
So I got an aftermarket oilpan for a GenII Hemi (RB) based with the typical flat mounting surface to the underside of the block. Tried to mock it up and it is totally too big to even mate up. This thing is made for something with a much wider crankcase.
Just looking for any info so I can properly describe what it is or know its useage????
This is not a thinly disguised for sale ad..... I have no idea what it would mate up to. I'm thinking Keith Black Hemi?
Thanks Dean
Re: Aftermarket Race B/RB Block Question......
[Re: DAYTONA540]
#1527407
11/02/13 01:58 PM
11/02/13 01:58 PM
Posts: 698 Alberta Canada
Edge
Alberta Canada
If it is an aluminum block with wider pan rail it is quite likely a TFX block, also check lifter bore and main bearing diameter. If it was an older fuel block likely to have 1 inch lifter bores and 3 inch mains ) this configuration was quote common for fuel blocks post up a picture and can tell for sure
76 Duster
work in progress
[Re: 23T Hemmee]
#1527410
11/03/13 03:19 PM
11/03/13 03:19 PM
Dean_Kuzluzski
Holly/MI
OK, thanks guys!! It is that much wider. I've considered making an adapter plate to use it but that is yet to be seen.
[Re: Dean_Kuzluzski]
#1527411
11/03/13 03:23 PM
11/03/13 03:23 PM
Edge
Alberta Canada
if it is a TFX block they make a specific pan for them also you will need a TFX specific gear drive as well
76 Duster
work in progress
