Re: 74 Charger brakes, a/c heater box
[Re: MIRADAMANia]
#1526881
11/02/13 03:08 PM
11/02/13 03:08 PM
RapidRobert
What Jim said, grab the disc brakes & the wrecker can then lift the front & tow it. If it's an 8&3/4 I'd want the axles & the pumpkin (for a spare) & if need be you can grab the pumpkin & bolt the axles back in & tow it & it will make it to the JY that way. If it's an 8&1/4 I'd also grab the drums/backing plates/small pieces
