What Jim said, grab the disc brakes & the wrecker can then lift the front & tow it. If it's an 8&3/4 I'd want the axles & the pumpkin (for a spare) & if need be you can grab the pumpkin & bolt the axles back in & tow it & it will make it to the JY that way. If it's an 8&1/4 I'd also grab the drums/backing plates/small pieces
