71 Challenger Wide Hood/Fender Molding Question #1526711
10/31/13 09:11 PM
10/31/13 09:11 PM
Waterford, MI
JAK Offline OP
JAK  Offline OP
Waterford, MI
How were the wide fender moldings mounted to fender? Pictures of screw and fender would be appreciated.
Re: 71 Challenger Wide Hood/Fender Molding Question [Re: JAK] #1526712
10/31/13 11:02 PM
10/31/13 11:02 PM
Toronto (YYZ) Ontario
YYZ Offline
YYZ  Offline
There are 6 special clips, 3 per fender that locate the trim and serve as an anchor for the screws that hold the fender pieces on
Re: 71 Challenger Wide Hood/Fender Molding Question [Re: JAK] #1526713
11/01/13 10:19 AM
11/01/13 10:19 AM
MG, Brazil
v8punch Offline
v8punch  Offline
MG, Brazil
Re: 71 Challenger Wide Hood/Fender Molding Question [Re: v8punch] #1526714
11/01/13 10:30 AM
11/01/13 10:30 AM
YYZ Offline
YYZ  Offline
So here are the clips (old photo - I can take closeups on the weekend)
The large end drops into the large holes pictured on the fenders - the small nub drops into the smaller holes to locate the clips.
The screws are a #6 or #8 oval head, chrome plated, that drive through the large part of the plastic clip and expand it like an anchor into the fender.
Re: 71 Challenger Wide Hood/Fender Molding Question [Re: YYZ] #1526715
11/01/13 10:36 AM
11/01/13 10:36 AM
YYZ Offline
YYZ  Offline
And the correct fasteners for the hood piece are these short, plated bolts with 3 raised dots along with the stamped speed nuts for the studs.
Re: 71 Challenger Wide Hood/Fender Molding Question [Re: YYZ] #1526716
11/01/13 10:40 AM
11/01/13 10:40 AM
YYZ Offline
YYZ  Offline
Closeup of the bolt
Re: 71 Challenger Wide Hood/Fender Molding Question [Re: YYZ] #1526717
11/02/13 10:33 PM
11/02/13 10:33 PM
Tampa, FL
tpabayflyer Offline
tpabayflyer  Offline
Tampa, FL
Wow... First time I have seen those clips??? I have an nos center piece with the correct bolts but the fender pieces did not come with the clips? I have set the fender pieces on and they sit pretty secure..... I was just planning on using the chrome screws?? TBF
71 Challenger 528 Hemi project
09 Gr Cherokee 5.7 hemi in da house!!
Re: 71 Challenger Wide Hood/Fender Molding Question [Re: YYZ] #1526718
11/05/13 12:17 AM
11/05/13 12:17 AM
MN
astrobuf Offline
astrobuf  Offline
MN
Vlad,
Give me a call.
Pat
So, are you really a Rocket Scientist?
Re: 71 Challenger Wide Hood/Fender Molding Question [Re: YYZ] #1526719
11/05/13 03:29 PM
11/05/13 03:29 PM
Calgary, Alberta Canada
m46rat Offline
m46rat  Offline
The heads of each screw are painted the same color of black as the painted black line on all three of the molded pot metal pieces.
Re: 71 Challenger Wide Hood/Fender Molding Question [Re: YYZ] #1526720
11/05/13 03:31 PM
11/05/13 03:31 PM
m46rat Offline
m46rat  Offline
And the correct fasteners for the hood piece are these short, plated bolts with 3 raised dots along with the stamped speed nuts for the studs. [/quot
The speed nuts are not used, the bolts are attached through the hood and directly into the back of the long hood moulding. You can see the holes in the back of the moulding where the bolts go.
Re: 71 Challenger Wide Hood/Fender Molding Question [Re: YYZ] #1526721
11/05/13 03:41 PM
11/05/13 03:41 PM
Shopping @ HoBo Fright
340SIX Offline
Doc Flappergas's Evil Twin
340SIX  Offline
That is what was on my 1971 318 flat hood car and it looked untouched when i got it
[img]https://i234.photobucket.com/albums/ee87/fast340six/sig%20pics/2840886-340SIX-1.jpg[/img]
VP of the MPM in New Orleans
73 Dart Sport 340/ 70 challenger vert. That may still get built, If I live long enough
