Re: the blue runner that did big wheelie at norwalk
[Re: a493demon]
#1526516
11/04/13 12:23 AM
11/04/13 12:23 AM
Posts: 404 Dana Point, CA
Fast Yeti
Dana Point, CA
is the issue out already ?
It's out with an on line subscription. The magazine will be out in stores at the end of the month.
[Re: mokid]
#1526521
11/04/13 03:11 PM
11/04/13 03:11 PM
Posts: 252 St.Louis, Mo.
mokid
St.Louis, Mo.
We F'd up our car same way today hard launch harder landing, so hard broke all the bolts holding steering column in, whole column was in my lap luckly was able to steer. bent alot of things.
We also bent new pan, and mounting bracket for crank triger pick up, for some reason front center trans pan bolt is now stripped and leaking fluid,
[Re: a493demon]
#1526522
11/04/13 08:30 PM
11/04/13 08:30 PM
Posts: 1,267 North, Alabama
D-50
North, Alabama
my car wasn't on the bumper so I was lucky. but this was out past the 60ft. cone
That looks cool 493demon,I will be a little nervous spraying on the line. It already leaves a little violent on motor. Congratulations on the front cover shot Fast Yeti...
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
