Question: original '70 'Cuda front valance hardware #152625
11/17/08 08:19 PM
11/17/08 08:19 PM
Ramona, CA
NicksGarage Offline OP
Ramona, CA
Does anyone have an original 1970 'Cuda front valance with its ORIGINAL trim hardware still in place? I need to know what 3 bolts/nuts were used as well as what 2 screws.nuts on the topside.
Photos would be great.
Re: Question: original '70 'Cuda front valance hardware [Re: NicksGarage] #152626
11/18/08 06:06 PM
11/18/08 06:06 PM
Ramona, CA
Ramona, CA
Re: Question: original '70 'Cuda front valance hardware [Re: NicksGarage] #152627
11/19/08 11:43 PM
11/19/08 11:43 PM
Calgary, Alberta Canada
m46rat Offline
m46rat  Offline
I have the silver zinc screws and plastic retainers NOS, but the two speed nuts are impossible to find new. I have a couple only.
Re: Question: original '70 'Cuda front valance hardware [Re: NicksGarage] #152628
11/20/08 02:09 AM
11/20/08 02:09 AM
Medina, Ohio
HEMICUDA Offline
HEMICUDA  Offline
Medina, Ohio
Here's the correct bolt that holds the valance insert in on a 70. It has the "ELH" on the head, 3/4" catured washer. I took this off my 3,900 mile survivor for a photo for a friend 2 days ago.
Re: Question: original '70 'Cuda front valance hardware [Re: HEMICUDA] #152629
11/20/08 02:10 AM
11/20/08 02:10 AM
Medina, Ohio
HEMICUDA Offline
HEMICUDA  Offline
Medina, Ohio
Re: Question: original '70 'Cuda front valance hardware [Re: HEMICUDA] #152630
11/20/08 03:32 AM
11/20/08 03:32 AM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
Touched up Mikes photo.
Re: Question: original '70 'Cuda front valance hardware [Re: Snoopy] #152631
11/20/08 03:39 AM
11/20/08 03:39 AM
Medina, Ohio
HEMICUDA Offline
HEMICUDA  Offline
Medina, Ohio
Thx Snoopy.
Re: Question: original '70 'Cuda front valance hardware [Re: HEMICUDA] #152632
11/20/08 07:51 AM
11/20/08 07:51 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
are these a 3/8" hex on a #10-24 machine thread bolt with what style point?
Re: Question: original '70 'Cuda front valance hardware [Re: gtx6970] #152633
11/20/08 08:36 AM
11/20/08 08:36 AM
m46rat Offline
m46rat  Offline
Snoopy: Do you have an engineering drawing showing the front valence and attaching hardware for a 70 or 71 Barracuda? I believe I have it at home, I will check tonight. If you have it please post, I do not believe it will show the bolt pictured.
Re: Question: original '70 'Cuda front valance hardware [Re: m46rat] #152634
11/20/08 09:00 AM
11/20/08 09:00 AM
Medina, Ohio
HEMICUDA Offline
HEMICUDA  Offline
Medina, Ohio
Are you saying this car is wrong?
Re: Question: original '70 'Cuda front valance hardware [Re: HEMICUDA] #152635
11/20/08 04:42 PM
11/20/08 04:42 PM
Snoopy Offline
Snoopy  Offline
Just so everyone is on the same page, are we talking about the lower steel valance or the plastic valance insert?
I think we are talking about the steel lower valance, but I could be wrong.
Re: Question: original '70 'Cuda front valance hardware [Re: Snoopy] #2942028
07/11/21 01:16 PM
07/11/21 01:16 PM
Dallas, Texas
FC7cuda Offline
FC7cuda  Offline
Dallas, Texas
Dwight,
Do you have the Engineers drawing to post? I took apart and original and I'm seeing the outer screws as 10/24 x 1" Oval Head Philips. Not the thread cuttings pan head that you're showing in your pic.
Ton
68 Charger
70 Cuda
