'70 Quarter Window Rear Channel Rubber Inserts? #1526225
10/31/13 01:21 AM
10/31/13 01:21 AM
California, USA
filmsurgeon Offline OP
California, USA
Need some help with this. Bought and just received this from Roseville (Part # AS2001A). It says it's for hardtops and convertibles.
http://www.rosevillemoparts.com/product_...roducts_id/7648
I assumed it was for something else, but now I don't really know where it goes. I have a '70 Challenger convertible. Does it go in the convertible top frame (as a weatherstrip) to seal the rear of the quarter window when it's rolled up? If so, it looks different than what is already there, and it's longer in length (possibly because hardtops required longer). Can anyone help? Thanks.
Re: '70 Quarter Window Rear Channel Rubber Inserts? [Re: filmsurgeon] #1526226
10/31/13 10:59 AM
10/31/13 10:59 AM
Ky
jt4406 Offline
jt4406  Offline
Ky
My car is not a convertible, nor did it have roll up rear windows (deputy model), however I did strip a 70 hardtop of it's rear window hardware to install in my car. Here's a couple pics of the part you mention installed, the brackets were both in my car, even though it did not originally use them. No idea if a convertible has the same brackets. By the way, I need one of these for the driver side, how long are the ones from Roseville?
jess
Yeah, it's hopped up to over 160...
Re: '70 Quarter Window Rear Channel Rubber Inserts? [Re: jt4406] #1526227
10/31/13 11:01 AM
10/31/13 11:01 AM
Ky
jt4406 Offline
jt4406  Offline
Ky
Sorry for the poor quality pics....
Re: '70 Quarter Window Rear Channel Rubber Inserts? [Re: jt4406] #1526228
10/31/13 11:03 AM
10/31/13 11:03 AM
Ky
jt4406 Offline
jt4406  Offline
Ky
top bracket
Re: '70 Quarter Window Rear Channel Rubber Inserts? [Re: jt4406] #1526229
10/31/13 11:05 AM
10/31/13 11:05 AM
Ky
jt4406 Offline
jt4406  Offline
Ky
clip on bottom rear of channel, clips onto bracket on wheelhousing.
jt
Re: '70 Quarter Window Rear Channel Rubber Inserts? [Re: jt4406] #1526230
10/31/13 08:51 PM
10/31/13 08:51 PM
California, USA
California, USA
jess
Thanks for the photos. They were very helpful. I checked my '70 Challenger convertible, and these bracket are not there. I think Roseville is incorrect in their description of the part. I don't believe these were used in convertibles.
