Locking transmission dipsticks #1524639
10/28/13 10:16 AM
10/28/13 10:16 AM
Tulsa, Oklahoma
340Cuda Offline OP
340Cuda  Offline OP
Tulsa, Oklahoma
Below is a list of NHRA approved locking dipsticks.
Does anyone know any of the companies below that have a product that works well in a 69 Barracuda with a small block, 904 and a CSR carbon fiber transmission shield?
I have one of the Lokar locking dipsticks and I don't see how I can get it to work.
A-1 Performance
ATI
B & M
BTE
Coan Racing
Cope Racing Transmissions
General Motors (GM)
Hughes Performance
Lokar
Mike's Transmission
Orscheln Products
Performance Automatic
Pro Trans
TCI Auto
Trans Dapt Performance
Transmission Specialties
Re: Locking transmission dipsticks [Re: 340Cuda] #1524640
10/28/13 11:28 AM
10/28/13 11:28 AM
Long Island, NY
ValiantRich Offline
ValiantRich  Offline
Long Island, NY
You can't get it to work. They don't fit with a stock floor. I had the same problem.
Re: Locking transmission dipsticks [Re: 340Cuda] #1524641
10/28/13 11:41 AM
10/28/13 11:41 AM
Riverside, Ca
G_bob Offline
G_bob  Offline
Riverside, Ca
GM dipstick from van at local salvage yard. Cut to length.
Re: Locking transmission dipsticks [Re: 340Cuda] #1524642
10/28/13 11:42 AM
10/28/13 11:42 AM
Mass.
8
80fbody Offline
80fbody  Offline
Mass.
Mancini Racing lists dipsticks specifically for use with the CSI shield. Might be worth a look.
Re: Locking transmission dipsticks [Re: G_bob] #1524643
10/28/13 11:45 AM
10/28/13 11:45 AM
tboomer Offline
tboomer  Offline
Re: Locking transmission dipsticks [Re: ValiantRich] #1524644
10/28/13 12:06 PM
10/28/13 12:06 PM
Tulsa, Oklahoma
340Cuda Offline OP
340Cuda  Offline OP
Tulsa, Oklahoma
I had to cut out the stock floor years ago to get the shield to work, the problem is that it hits the shield.
Re: Locking transmission dipsticks [Re: G_bob] #1524645
10/28/13 12:07 PM
10/28/13 12:07 PM
Tulsa, Oklahoma
340Cuda Offline OP
340Cuda  Offline OP
Tulsa, Oklahoma
Not sure this would be NHRA approved, however it does say GM...
Re: Locking transmission dipsticks [Re: 80fbody] #1524646
10/28/13 12:08 PM
10/28/13 12:08 PM
Tulsa, Oklahoma
340Cuda Offline OP
340Cuda  Offline OP
Tulsa, Oklahoma
John Cope also lists one, at $45.00 I have one on the way.
Re: Locking transmission dipsticks [Re: 340Cuda] #1524647
10/28/13 12:08 PM
10/28/13 12:08 PM
tboomer Offline
tboomer  Offline
Mine passes tech...
Re: Locking transmission dipsticks [Re: 340Cuda] #1524648
10/28/13 12:11 PM
10/28/13 12:11 PM
Guitar Jones Offline
I have a Hughes and it does the same thing. I just made a small extension to bolt to the tab that spaces it out about 1 inch.
Re: Locking transmission dipsticks [Re: tboomer] #1524649
10/28/13 12:12 PM
10/28/13 12:12 PM
Indy
FlyFish Offline
FlyFish  Offline
Indy
I have this one, works fine as long as I keep my stock dipstick for actually checking the trans.
http://www.summitracing.com/parts/ati-973081/overview/
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
Re: Locking transmission dipsticks [Re: ValiantRich] #1524650
10/28/13 01:06 PM
10/28/13 01:06 PM
Renton Washington
Triple Threat Offline
Renton Washington
Wish someone would have told me that before i spent $100 on one.
I too run the cut to fit junkyard model. Cope Builds one to fit your application though.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: Locking transmission dipsticks [Re: FlyFish] #1524651
10/28/13 01:12 PM
10/28/13 01:12 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
that is the ticket..
Tony
70 AARCuda Vitamin C
Re: Locking transmission dipsticks [Re: G_bob] #1524652
10/28/13 02:11 PM
10/28/13 02:11 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
THIS......................No one`s ever questioned it on my car anyhow..............
Re: Locking transmission dipsticks [Re: Thumperdart] #1524653
10/28/13 02:23 PM
10/28/13 02:23 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
The locking style is a GM dipstick, big deal.
Re: Locking transmission dipsticks [Re: Challenger 1] #1524654
10/28/13 03:13 PM
10/28/13 03:13 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
......WHAT?
Re: Locking transmission dipsticks [Re: 340Cuda] #1524655
10/28/13 03:50 PM
10/28/13 03:50 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
I got a Lokar stick but for a TH350 with the short trans mount and it clears thr floor and seals well.
Re: Locking transmission dipsticks [Re: Clanton] #1524656
10/28/13 04:27 PM
10/28/13 04:27 PM
Tulsa, Oklahoma
340Cuda Offline OP
340Cuda  Offline OP
Tulsa, Oklahoma
Thanks everyone, I'll let you know how the CRT works out.
Bill
Re: Locking transmission dipsticks [Re: FlyFish] #1524657
10/28/13 04:30 PM
10/28/13 04:30 PM
Cincinnati, Ohio
d7cook Offline
d7cook  Offline
Cincinnati, Ohio
That's what I use. I also use MAPP gas to heat and bend the tube to whatever shape I need and then weld on a new brace. Remark the old dipstick for the right level and keep it in the car for when you actually need it. And remember you can only bend the tube in one axis.
1967 Coronet, 1989 Daytona tube chassis. Former cars, 66 Charger, 67 R/T, 69 Coronet, 67 Dart GT. -Banned for life from V8Buick.com-
Re: Locking transmission dipsticks [Re: d7cook] #1524658
10/28/13 06:07 PM
10/28/13 06:07 PM
Mooresburg, Tn
'72CudaRacer Offline
Mooresburg, Tn
I have the correct one in my car, the locking one (salvage yard locking GM w/ the stick part cut to about 10") in the trailer, in case it's needed in tech.
Brian
