Re: Locking transmission dipsticks
[Re: ValiantRich]
#1524644
10/28/13 12:06 PM
10/28/13 12:06 PM
Posts: 3,508 Tulsa, Oklahoma
340Cuda
Tulsa, Oklahoma
You can't get it to work. They don't fit with a stock floor. I had the same problem.
I had to cut out the stock floor years ago to get the shield to work, the problem is that it hits the shield.
[Re: G_bob]
#1524645
10/28/13 12:07 PM
10/28/13 12:07 PM
340Cuda
Tulsa, Oklahoma
GM dipstick from van at local salvage yard. Cut to length.
Not sure this would be NHRA approved, however it does say GM...
[Re: 80fbody]
#1524646
10/28/13 12:08 PM
10/28/13 12:08 PM
340Cuda
Tulsa, Oklahoma
Mancini Racing lists dipsticks specifically for use with the CSI shield. Might be worth a look.
John Cope also lists one, at $45.00 I have one on the way.
[Re: 340Cuda]
#1524648
10/28/13 12:11 PM
10/28/13 12:11 PM
Posts: 20,622 in a cattle trailer down by th...
Guitar Jones
I have a Hughes and it does the same thing. I just made a small extension to bolt to the tab that spaces it out about 1 inch.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
[Re: tboomer]
#1524649
10/28/13 12:12 PM
10/28/13 12:12 PM
Posts: 1,178 Indy
FlyFish
Indy
I have this one, works fine as long as I keep my stock dipstick for actually checking the trans. http://www.summitracing.com/parts/ati-973081/overview/
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
[Re: Thumperdart]
#1524653
10/28/13 02:23 PM
10/28/13 02:23 PM
Challenger 1
Cincinnati, Ohio
THIS......................No one`s ever questioned it on my car anyhow..............
The locking style is a GM dipstick, big deal.
[Re: FlyFish]
#1524657
10/28/13 04:30 PM
10/28/13 04:30 PM
Posts: 290 Cincinnati, Ohio
d7cook
Cincinnati, Ohio
That's what I use. I also use MAPP gas to heat and bend the tube to whatever shape I need and then weld on a new brace. Remark the old dipstick for the right level and keep it in the car for when you actually need it. And remember you can only bend the tube in one axis.
1967 Coronet, 1989 Daytona tube chassis.
Former cars, 66 Charger, 67 R/T, 69 Coronet, 67 Dart GT.
-Banned for life from V8Buick.com-
