Here's my frame project #1524486
10/27/13 10:05 PM
10/27/13 10:05 PM
Back home in PA
BulletBob Offline OP
Back home in PA
At the first of this year I stated in a post that I would be doing a frame for my 84 RamCharger that I would move the engine crossmember up in the rails & the rails down into the crossmember resulting in a 2 3/4" drop
Technically this is my 2nd time doing this as I took a junk frame & cut it up & tacked it all together about 5 years ago or so before moving here
I didn't mount a rack but shoved a Sundance rack up there & I know a rack is possible
Some boxing of the crossmember where the oil pan sits is required & when I'm done there will be no need for problem solver bushings for the upper arms
I want to do 6" front & 8" rear drop using stock type suspension
Here's the pics of the start
Re: Here's my frame project [Re: BulletBob] #1524487
10/27/13 10:08 PM
10/27/13 10:08 PM
Back home in PA
Back home in PA
This is how it looked after two days of here & there working on it & help from the company forklift
Re: Here's my frame project [Re: BulletBob] #1524488
10/27/13 10:12 PM
10/27/13 10:12 PM
Back home in PA
Back home in PA
Here's where it will reside
This spot will be a unique interpretation of code Nazi rules but will be a shop of sorts when finished
Re: Here's my frame project [Re: BulletBob] #1524489
10/27/13 10:15 PM
10/27/13 10:15 PM
Back home in PA
Back home in PA
I want to sit lower than this & ride the same
Re: Here's my frame project [Re: BulletBob] #1524490
10/27/13 10:17 PM
10/27/13 10:17 PM
Back home in PA
Back home in PA
That would be 2 inches lower than this
Re: Here's my frame project [Re: BulletBob] #1524491
10/27/13 10:56 PM
10/27/13 10:56 PM
Amarillo, Tx
old_goat Offline
Six Abuser
old_goat  Offline
Six Abuser
Amarillo, Tx
About a 1 1/2" slant chop would be cool. Stock height at rear. Just enough to make those who know what they are looking at look twice, or maybe 3 times to see whats wrong....couldnt pull it off on a pickup.
I have another trick up my sleeve for mine...
84 D150 440/727
79 /6 swb D150
1964 A100 window van. Just because it has spark plug tubes doesn't mean it's a Hemi.
If ya haven't been there, ya just wouldn't understand.
Re: Here's my frame project [Re: old_goat] #1524492
10/27/13 11:15 PM
10/27/13 11:15 PM
Back home in PA
Back home in PA
I don't doubt that Bill!
Re: Here's my frame project [Re: BulletBob] #1524493
10/28/13 12:04 AM
10/28/13 12:04 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
In my neighborhood 2" lower wouldn't be drivable. You'd be banging and scraping all the time.
Re: Here's my frame project [Re: stumpy] #1524494
10/28/13 12:12 AM
10/28/13 12:12 AM
Marion Illinois
72d100 Offline
72d100  Offline
Marion Illinois
i still want to do a crown vic swap
Re: Here's my frame project [Re: 72d100] #1524495
10/28/13 12:28 AM
10/28/13 12:28 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
a Crowb Vic on a RC chassis would be different..
I am truckless..
Re: Here's my frame project [Re: stumpy] #1524496
10/28/13 02:49 AM
10/28/13 02:49 AM
Sunny South Florida
Golden-Arm Offline
Golden-Arm  Offline
Sunny South Florida
In my driveway 2" lower wouldn't be drivable. You'd be banging and scraping all the time.
*fixed it for ya.
Re: Here's my frame project [Re: stumpy] #1524497
10/28/13 03:22 AM
10/28/13 03:22 AM
Back home in PA
Back home in PA
Stumpy, I've already got that figured out
I've got some 2X4X3/16" angle so I figure I can cut the profile down on the frame & box it at the same time at it's lowest point
I have some oval shaped exhaust tubing to help accomplish clearance on that
Re: Here's my frame project [Re: BulletBob] #1524498
07/09/14 02:18 AM
07/09/14 02:18 AM
Back home in PA
Back home in PA
Here's how it looked Saturday AM
Here's how it looked Saturday evening
Re: Here's my frame project [Re: BulletBob] #1524499
07/12/14 09:44 PM
07/12/14 09:44 PM
Marion Illinois
72d100 Offline
72d100  Offline
Marion Illinois
you lost some frame somewhere
Re: Here's my frame project [Re: 72d100] #1524500
07/14/14 11:23 AM
07/14/14 11:23 AM
Back home in PA
Back home in PA
I'm going to put the front cross member in my current frame after I modify it
Re: Here's my frame project [Re: BulletBob] #1524501
07/20/14 06:50 PM
07/20/14 06:50 PM
Back home in PA
Back home in PA
Managed to get to the heart of the project today after whittling with the torch,& grinder along with the hand held sledge & ironworker's punch
Had to wirebrush where the motor mounts welded down & do all the rivets for them & the upper a arm mounts
[image]http://i983.photobucket.com/albums/ae312/dodgeaddict2/Dodge%20truck%20stuff/Lowered%20crossmember%20build/20140720_130745_resized_zps81bb790d.jpg[/image]
[image]http://i983.photobucket.com/albums/ae312/dodgeaddict2/Dodge%20truck%20stuff/Lowered%20crossmember%20build/20140720_130752_resized_zps799f0ef2.jpg?t=1405888900[/image]
Re: Here's my frame project [Re: BulletBob] #1524502
07/22/14 12:14 AM
07/22/14 12:14 AM
Back home in PA
Back home in PA
I'll try this again
The motor mount pads & rivets had to go first then the rivet on each side hidden by the mounts & the bolts
After some hammering & using the punch
My goal for this is achieved Grind & pressure wash next
Re: Here's my frame project [Re: BulletBob] #1524503
08/03/14 08:31 PM
08/03/14 08:31 PM
Back home in PA
Back home in PA
Today I unpiled the stuff off the Mustang & pushed it's bleeding self out into my drive for it's trip to my slab out back to get finished eventually
The trans bled out from a seal
Cat litter was out & cat food was full so I improvised (cat disappeared a year ago)
Her's a pic of my RamCharger backed out in the street awaiting to be pulled back up so I can pull the engine & trans back out to swap the crossmembers & cutting the frame
