Re: Here's my frame project
[Re: stumpy]
#1524497
10/28/13 03:22 AM
10/28/13 03:22 AM
Posts: 6,048 Back home in PA
BulletBob
Back home in PA
In my neighborhood 2" lower wouldn't be drivable. You'd be banging and scraping all the time.
Stumpy, I've already got that figured out I've got some 2X4X3/16" angle so I figure I can cut the profile down on the frame & box it at the same time at it's lowest point
I have some oval shaped exhaust tubing to help accomplish clearance on that
[Re: BulletBob]
#1524501
07/20/14 06:50 PM
07/20/14 06:50 PM
BulletBob
Back home in PA
Managed to get to the heart of the project today after whittling with the torch, & grinder along with the hand held sledge & ironworker's punch Had to wirebrush where the motor mounts welded down & do all the rivets for them & the upper a arm mounts [image]http://i983.photobucket.com/albums/ae312/dodgeaddict2/Dodge%20truck%20stuff/Lowered%20crossmember%20build/20140720_130745_resized_zps81bb790d.jpg[/image] [image]http://i983.photobucket.com/albums/ae312/dodgeaddict2/Dodge%20truck%20stuff/Lowered%20crossmember%20build/20140720_130752_resized_zps799f0ef2.jpg?t=1405888900[/image]
