Page 1 of 3 1 2 3
T&T results with 13 lbs boost #1523649
10/26/13 02:27 PM
10/26/13 02:27 PM
Houston, Texas
TheOtherDodge Offline OP
Houston, Texas
Previously i was running about 10 sometimes touching 11 lbs of boost at the top of third gear. Last night i tried 13lbs touching 14 at the top of third...
Leaving at 3200 rpms (5 lbs) and shifting at 6000 crossing at 6200: 1.42, 6.32 @ 108.8, 9.97 @ 133.3
I will get a boost controller to help with the launch....
Re: T&T results with 13 lbs boost [Re: TheOtherDodge] #1523650
10/26/13 02:44 PM
10/26/13 02:44 PM
WA
JD Dart Offline
JD Dart  Offline
WA
wow That should be the fastest Dakota in the 9's But wait it's not an R/T so doesn't count. But for me it does great job
Re: T&T results with 13 lbs boost [Re: JD Dart] #1523651
10/26/13 03:26 PM
10/26/13 03:26 PM
ohio
all spooled up Offline
ohio
great pass killer 60 foot for a turbo car or truck what does it weight
Re: T&T results with 13 lbs boost [Re: TheOtherDodge] #1523652
10/26/13 04:27 PM
10/26/13 04:27 PM
Pacifica, CA
Devilbrad Offline
Devilbrad  Offline
Pacifica, CA
Yowza! Nice dude!!
Re: T&T results with 13 lbs boost [Re: Devilbrad] #1523653
10/26/13 05:39 PM
10/26/13 05:39 PM
Toronto
mshred Online content
mshred  Online Content
Toronto
Awesome! Was it spinning off the line?
Re: T&T results with 13 lbs boost [Re: TheOtherDodge] #1523654
10/26/13 06:36 PM
10/26/13 06:36 PM
Fitchburg,Massachusetts
MPerry Offline
Mopahts memba'
MPerry  Offline
Mopahts memba'
You have any posts lingering of the build up? I'm really curious about turbos.
Re: T&T results with 13 lbs boost [Re: TheOtherDodge] #1523655
10/26/13 10:18 PM
10/26/13 10:18 PM
gregsdart Offline
gregsdart  Offline
Nice ride, James!
Re: T&T results with 13 lbs boost [Re: TheOtherDodge] #1523656
10/26/13 11:29 PM
10/26/13 11:29 PM
Andrews,In. U.S.of A.
67_Satellite Offline
I found a cheap 10" converter and a slightly larger cam for a winter upgrade. If I had your 60' I would be a happy MF'er. That would put me at 11.20's@ 121. Not gonna hold out hope for .7 sec. improvment,but it's gonna get better.
Re: T&T results with 13 lbs boost [Re: TheOtherDodge] #1523657
10/26/13 11:41 PM
10/26/13 11:41 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
That is COOL!
Re: T&T results with 13 lbs boost [Re: Clanton] #1523658
10/27/13 12:06 AM
10/27/13 12:06 AM
Houston, Texas
Houston, Texas
Thanks guys!
I dont post as much here as i used too,but i still troll here!
With me in it, 3390 lbs
No spin on that pass but i tried 15 lbs of boost and blew the tires.
Its a 389 sb, home ported eddy heads, .520 hydraulic roller, M1 intake, FAST ignition, 76 mm turbo, 727, dana with 3.55 gears, 315 drag radials, ladder bars, magaflow muffs, ps, pb, ac, full interior.
Re: T&T results with 13 lbs boost [Re: TheOtherDodge] #1523659
10/27/13 12:33 AM
10/27/13 12:33 AM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
Are you running pump gas or E85? What fuel injectors are your using?
Re: T&T results with 13 lbs boost [Re: goldmember] #1523660
10/27/13 08:15 AM
10/27/13 08:15 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Congrats that was a nice pass. Nice having a nine sec street truck.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: T&T results with 13 lbs boost [Re: 1967dartgt] #1523661
10/27/13 09:21 AM
10/27/13 09:21 AM
tboomer Offline
tboomer  Offline
Very nice James!!
Re: T&T results with 13 lbs boost [Re: tboomer] #1523662
10/27/13 10:18 AM
10/27/13 10:18 AM
Houston, Texas
Houston, Texas
They are 83 lb injectors.
My goal when I started the build was a very streetable 10 second truck so I think I accomplished and exceeded that!
Thanks Ted!
Re: T&T results with 13 lbs boost [Re: TheOtherDodge] #1523663
10/27/13 11:21 AM
10/27/13 11:21 AM
Pacifica, CA
Devilbrad Offline
Devilbrad  Offline
Pacifica, CA
I would love to see some video!
Re: T&T results with 13 lbs boost [Re: Devilbrad] #1523664
10/27/13 11:54 AM
10/27/13 11:54 AM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
94 Dakota, sb, 76mm turbo AC, PS, PB, full interior! 9.97 @ 133.33
^^^ That says it all, very cool!!
Can you post a photo of the engine?
Re: T&T results with 13 lbs boost [Re: TheOtherDodge] #1523665
10/27/13 03:06 PM
10/27/13 03:06 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
Very nice man! Gotta feel great to get that 9 sec slip!
Get a boost controller and a trans brake in that thing. It will make all the difference in the world for getting it down the track.
Re: T&T results with 13 lbs boost [Re: TheOtherDodge] #1523666
10/27/13 03:19 PM
10/27/13 03:19 PM
Buford, GA
I_bleed_MOPAR Offline
Buford, GA
Congrats, TOD. You've got that thing rollin'.
Tim
'71 Charger 383/727
'17 Challenger SXT (Wifeys car wink )
Re: T&T results with 13 lbs boost [Re: I_bleed_MOPAR] #1523667
10/27/13 03:22 PM
10/27/13 03:22 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
Nice running turbo truck!
Re: T&T results with 13 lbs boost [Re: RobX4406] #1523668
10/27/13 09:41 PM
10/27/13 09:41 PM
Houston, Texas
Houston, Texas
Here are a few pics...
Page 1 of 3 1 2 3
