T&T results with 13 lbs boost
#1523649
10/26/13 02:27 PM
10/26/13 02:27 PM
Posts: 4,953 Houston, Texas
TheOtherDodge
Houston, Texas
Previously i was running about 10 sometimes touching 11 lbs of boost at the top of third gear. Last night i tried 13lbs touching 14 at the top of third... Leaving at 3200 rpms (5 lbs) and shifting at 6000 crossing at 6200: 1.42, 6.32 @ 108.8, 9.97 @ 133.3 I will get a boost controller to help with the launch....
Re: T&T results with 13 lbs boost
[Re: Clanton]
#1523658
10/27/13 12:06 AM
10/27/13 12:06 AM
TheOtherDodge
Houston, Texas
Thanks guys! I dont post as much here as i used too,but i still troll here! With me in it, 3390 lbs No spin on that pass but i tried 15 lbs of boost and blew the tires. Its a 389 sb, home ported eddy heads, .520 hydraulic roller, M1 intake, FAST ignition, 76 mm turbo, 727, dana with 3.55 gears, 315 drag radials, ladder bars, magaflow muffs, ps, pb, ac, full interior.
[Re: goldmember]
#1523660
10/27/13 08:15 AM
10/27/13 08:15 AM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
Congrats that was a nice pass. Nice having a nine sec street truck.
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: tboomer]
#1523662
10/27/13 10:18 AM
10/27/13 10:18 AM
TheOtherDodge
Houston, Texas
They are 83 lb injectors. My goal when I started the build was a very streetable 10 second truck so I think I accomplished and exceeded that! Thanks Ted!
[Re: Devilbrad]
#1523664
10/27/13 11:54 AM
10/27/13 11:54 AM
Posts: 17,918 Akron, Ohio
ProSport
Akron, Ohio
94 Dakota, sb, 76mm turbo AC, PS, PB, full interior! 9.97 @ 133.33
^^^ That says it all, very cool!!
Can you post a photo of the engine?
[Re: TheOtherDodge]
#1523666
10/27/13 03:19 PM
10/27/13 03:19 PM
Posts: 8,672 Buford, GA
I_bleed_MOPAR
Buford, GA
Congrats, TOD. You've got that thing rollin'. Tim
'71 Charger 383/727 '17 Challenger SXT (Wifeys car )
