"Fading Color" cam test article #1523048
10/24/13 11:40 PM
10/24/13 11:40 PM
Way North Idaho
1KoolBee Offline OP
1KoolBee  Offline OP
Way North Idaho
Now that my motor build is about done, I began second guessing my decision to stick with my .557 mopar cam & maybe swap in a Lunati 60341 or 60342 cam. I decided to take a close look at the Mopar "Fading Color" magazine cam test article from a few months ago. I built a chart of the specs and results & found it pretty telling. Looking carefully at the results I spotted some inconsistencies in the way the specs were advertised in the article. Bottom line, the MP .557 & .590 cams fared well given their age, I think I will stick with my original plan. One of the first things that stands out is that comparing most of the cams of the article to the .557 cam was like comparing apples and oranges as most had way more duration and lift. Also, after giving the cam vendors free reign to spec any custom grind they wanted, only one manufacturer really outperformed the old .590 MP grind. I realize every motor combo responds differently to varying cam parameters, but this was still a pretty telling test.(See attached PDF).
7899803-Cams.pdf (409 downloads)
'68 Bee 383/TF/Factory Air...high school sweetheart
'67 GTX Clone project,500 six pack,Hemi4-speed,Dana
05 Dodge Viper, 505 V-10, 6-speed Tremec
Re: "Fading Color" cam test article [Re: 1KoolBee] #1523049
10/24/13 11:50 PM
10/24/13 11:50 PM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
I cant get your file to download. But I will say this,every manufacturer was given the same chance,only two took the time to ask the right questions.
A couple of companies were even questioned on their choice and stuck with a recommendation anyway.
I'm sticking my neck out saying this,but read between the lines .
Keith
Re: "Fading Color" cam test article [Re: 1KoolBee] #1523050
10/24/13 11:52 PM
10/24/13 11:52 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
What engine, as those tests were with a SB
Re: "Fading Color" cam test article [Re: Dunnuck Racing] #1523051
10/25/13 12:02 AM
10/25/13 12:02 AM
Way North Idaho
1KoolBee Offline OP
1KoolBee  Offline OP
Way North Idaho
Keith
Should work with current Acrobat reader Let me guess, the ones who asked questions were at the top of the heap?
Re: "Fading Color" cam test article [Re: Sport440] #1523052
10/25/13 12:04 AM
10/25/13 12:04 AM
Way North Idaho
1KoolBee Offline OP
1KoolBee  Offline OP
Way North Idaho
I'm running 500 BB, article was 421 SB (4.125 Stroke)
Re: "Fading Color" cam test article [Re: 1KoolBee] #1523053
10/25/13 12:25 AM
10/25/13 12:25 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
That cam barely supports a small block in my opinion and my stuff has always gone faster w/bigger than recommended cams by the "experts"........... Is it up and running yet? Never too late to step up.
Re: "Fading Color" cam test article [Re: 1KoolBee] #1523054
10/25/13 12:29 AM
10/25/13 12:29 AM
Northern Indiana
Northern Indiana
Probably because I just use an Android phone right now.
The guys that asked questions did the best,others just picked something out of a catalogue. There are a lot of things that I just can't say but if you read it carefully you might pick up.
Keith
Re: "Fading Color" cam test article [Re: Thumperdart] #1523055
10/25/13 12:29 AM
10/25/13 12:29 AM
Way North Idaho
1KoolBee Offline OP
1KoolBee  Offline OP
Way North Idaho
Dom, motor is still on the stand, but I plan to run 3.54 gears and power brakes. I figure I'm pushing the limits even with the .557 cam. I talked to Lunati, they recommended the 60341 or the 60342 on 112 centers. With 1.6 rockers, 60342 would net similar duration and .586/.608 lift, but would the time & expense really yield a significant power increase. The article leads me to believe that the answer is no unless I'm willing to spring for a roller.
Re: "Fading Color" cam test article [Re: 1KoolBee] #1523056
10/25/13 12:49 AM
10/25/13 12:49 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Which heads? What do they flow? I would run a 108 lsa myself installed around 104-105 for more down low grunt but that`s just me.
Re: "Fading Color" cam test article [Re: Thumperdart] #1523057
10/25/13 01:32 AM
10/25/13 01:32 AM
Way North Idaho
1KoolBee Offline OP
1KoolBee  Offline OP
Way North Idaho
Stock Eddys, so 290/217 @.600 if you believe the glossy sales brochure. I thought about running the off-the-shelf 60342 advanced a bit, I'm sure it would make a little more power, but how much? 15 Hp probably not worth the hassle, but 40-50, for sure. Guess it would be handy if someone did a similar test on a 500 BB with the OOTB Lun 60341, 60342, MP.557 & .590,maybe Comp XE295HL & other, plus Hughes 4852 & 5256. I realize this kind of cam comparo is a lot of work as I'm sure Keith can attest.
Re: "Fading Color" cam test article [Re: 1KoolBee] #1523058
10/25/13 10:03 AM
10/25/13 10:03 AM
Northern Indiana
Northern Indiana
I have maybe a dozen cams for big blocks and most of a 499 and planned on doing a similar test. But after the amount of money Ive lost writing articles I'm not sure if or when it will happen
Keith
Re: "Fading Color" cam test article [Re: 1KoolBee] #1523059
10/25/13 11:32 AM
10/25/13 11:32 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Can`t say for sure what hp difference you`d see in the different cams BUT, I guarantee those heads ported by yours truly AND a stout cam would easily give you the 50+...............
Re: "Fading Color" cam test article [Re: Dunnuck Racing] #1523060
10/25/13 11:46 AM
10/25/13 11:46 AM
AndyF Offline
AndyF  Offline
Keith
I'm with you there.
Re: "Fading Color" cam test article [Re: Dunnuck Racing] #1523061
10/25/13 12:11 PM
10/25/13 12:11 PM
Way North Idaho
1KoolBee Offline OP
1KoolBee  Offline OP
Way North Idaho
Keith
Keith, yeah I can only imagine the time & $ it took to do the SB article. Thanks for doing that, its still pretty informative even for us BB guys. Would be nice if the magazines & cam vendors could do more to help cover costs.
Re: "Fading Color" cam test article *DELETED* [Re: 1KoolBee] #1523062
10/25/13 12:39 PM
10/25/13 12:39 PM
Moparts
SSDart Offline
SSDart  Offline
Moparts
Post deleted by SSDart
Re: "Fading Color" cam test article [Re: SSDart] #1523063
10/25/13 12:46 PM
10/25/13 12:46 PM
Northern Indiana
Northern Indiana
Yes,I have a dyno in my shop. If I had to rent dyno time I never would have been able to do it. Basically I recovered the cost of the cams for writing the article but nothing for fuel,oil,gaskets,time,wear and tear. Although I will mention that between Todd at Competition Wedge Engines and Greg from Superformance gaskets they saved me some money by donating the gaskets. Cant say enough about the quality of those gaskets and how much it was appreciated.
Keith
Re: "Fading Color" cam test article [Re: Dunnuck Racing] #1523064
10/25/13 12:55 PM
10/25/13 12:55 PM
Moparts
SSDart Offline
SSDart  Offline
Moparts
Keith
Ya I figured that later. when I read the notes I thought it was a compolation of tests........ Nice job Did you advance the cams as per cam companies recomendation? If so did any of them say why they felt they needed to advance them and not choose another cam?
Re: "Fading Color" cam test article [Re: SSDart] #1523065
10/25/13 12:59 PM
10/25/13 12:59 PM
Northern Indiana
Northern Indiana
Thanks,
I degreed each cam to the cam cards recommend installed centerline for the article . I figured that was the only way to be fair . A few were tested with different installed centerlines and a few other cams were also tested but not for the article .
Keith
Re: "Fading Color" cam test article [Re: Dunnuck Racing] #1523066
10/25/13 02:26 PM
10/25/13 02:26 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Thanks Keith . I have the Hughes cam that is one size smaller than the one you tested in my pump gas 408. It runs strong and pull from anywhere in the rpm range. The MP 590 surprised me though, it made very good power.
Re: "Fading Color" cam test article [Re: Dunnuck Racing] #1523067
10/25/13 03:28 PM
10/25/13 03:28 PM
sweden
sshemi Offline
sshemi  Offline
sweden
Thanks,
Keith
What article is this???
I must have totally missed it.
Can i see it somewhere online?
