340 exhaust manifold pictres needed - correct overspray #1522405
10/23/13 11:13 PM
10/23/13 11:13 PM
mopar346 Offline OP
Let me tell ya about fat chicks!
mopar346  Offline OP
I need some good pictures to show my powder coater the basic engine paint overspray pattern.
Careful, your character's showing!
Re: 340 exhaust manifold pictres needed - correct overspray [Re: mopar346] #1522406
10/23/13 11:42 PM
10/23/13 11:42 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
There was no "pattern" the manifolds were bolted on and painted with the engine, no effort was made to paint them (or not) most got a lot of coverage most of which burned off shortly after start up leaving paint on areas that didn't get as hot (mostly the flanges where they meet the heads and the collectors at the heat riser, etc.).
FWIW I don't see know how much help a powder coater is going to be in accomplishing a true factory appearance.
Re: 340 exhaust manifold pictres needed - correct overspray [Re: ScottSmith_Harms] #1522407
10/24/13 02:26 AM
10/24/13 02:26 AM
So Cal
autoxcuda Online content
autoxcuda  Online Content
So Cal
There will be lighter covered areas on the block where the exhaust manifolds get in the way of the spraying paint.
Re: 340 exhaust manifold pictres needed - correct overspray [Re: autoxcuda] #1522408
10/24/13 02:32 AM
10/24/13 02:32 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Same is true of bottoms and flanges of oil pans, because the spray gun didn't get low down.
Re: 340 exhaust manifold pictres needed - correct overspray [Re: kentj340] #1522409
10/24/13 08:22 AM
10/24/13 08:22 AM
mopar346 Offline OP
mopar346  Offline OP
Thanks guys, I am familiar with most everything you discribe and have described it to him. I just wante pictures to give him a visual and yes it would be tough for him to get the burned off effect, but the best chance he has is to have pictures.
Re: 340 exhaust manifold pictres needed - correct overspray [Re: mopar346] #1522410
10/24/13 10:45 AM
10/24/13 10:45 AM
across the river from Portland...
472 R/T SE Offline
472 R/T SE  Offline
I always wanted to figure out a way to somehow preserve the overspray on the manifolds. The enclosed trailer look on a driver, .
[color:"purple"]HELP SUPPORT THE REGISTRIES.All cars matter.
1970 Charger Registry
I like to sleep For I'm walking in my dreams.
Live life like every DAY is your last!
Chrysler R/T Club
[/color]
Re: 340 exhaust manifold pictres needed - correct overspray [Re: 472 R/T SE] #1522411
10/24/13 10:56 AM
10/24/13 10:56 AM
mopar346 Offline OP
mopar346  Offline OP
Well, I have seen hi-tem powder coating retain the look, I just don't have any pictures. Surely someone on Moparts has done it and/or has some pictures.
Re: 340 exhaust manifold pictres needed - correct overspray [Re: mopar346] #1522412
10/24/13 01:27 PM
10/24/13 01:27 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
As mentioned the manifolds masked areas of the block from paint and gun position left many lower areas bare or thinly painted. Since powder coat is electrostatically applied I'm not sure how they only cover certain areas while leaving others bare. Not to mention that even high temp powder coats will burn off of most manifolds. Are you planing to have them powder coat the completed engine with manifolds as an assembly?
Re: 340 exhaust manifold pictres needed - correct overspray [Re: ScottSmith_Harms] #1522413
10/24/13 01:55 PM
10/24/13 01:55 PM
mopar346 Offline OP
mopar346  Offline OP
No not as an assemble, I hae seen what I a talking about at shows plenty of times I just cant find a good picture. It is completely cast color and then appears oversprayed at the top, heavy in the beginning and fading out as it gets further away from the flange. Here is one of the only pictures I can find.
Re: 340 exhaust manifold pictres needed - correct overspray [Re: mopar346] #1522414
10/24/13 01:58 PM
10/24/13 01:58 PM
mopar346 Offline OP
mopar346  Offline OP
Re: 340 exhaust manifold pictres needed - correct overspray [Re: mopar346] #1522415
10/24/13 02:30 PM
10/24/13 02:30 PM
Nashville, TN
MOPARMIKE69 Offline
MOPARMIKE69  Offline
Nashville, TN
Pictures are not showing up. If you want to make it really factory you have to paint the engine and manifolds etc together. Also no paint on the manifolds before painting the orange. That cannot be done with the powdercoating process. You can "simulate" the factory process by painting or ceramic coating the manifolds off the car, and hitting them with paint around the edge, but it will only simulate the look.
My says you have to commit. Either have the manifolds look nice and not paint them with engine paint, or do it like the factory and have them burn off and rust. Or never start the car?
69 Road Runner vert
69 GTX hard top
70 Road Runner 4 speed
70 Hemi Cuda vert
Re: 340 exhaust manifold pictres needed - correct overspray [Re: MOPARMIKE69] #1522416
10/24/13 02:52 PM
10/24/13 02:52 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Re: 340 exhaust manifold pictres needed - correct overspray [Re: ScottSmith_Harms] #1522417
10/24/13 03:28 PM
10/24/13 03:28 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
I usually have them ceramic coated and then bolt on and shoot the engine.
This last set were powder coated silver/gray bolted on and shot.
Like Scott said whatever burns off burns off, why over complicate the process?
Ron
Re: 340 exhaust manifold pictres needed - correct overspray [Re: RJS] #1522418
10/24/13 03:41 PM
10/24/13 03:41 PM
472 R/T SE Offline
472 R/T SE  Offline
Ron
For some people, it's part of the fun.
Re: 340 exhaust manifold pictres needed - correct overspray [Re: RJS] #1522419
10/24/13 03:44 PM
10/24/13 03:44 PM
mopar346 Offline OP
mopar346  Offline OP
That is the problem with my AAR, I get too caught up in aking it right or what is currently perceived to be right. It would be so much more fun to build it just to look good and be enjoyable.
Thanks for the input, on to another subject.
Re: 340 exhaust manifold pictres needed - correct overspray [Re: mopar346] #1522420
10/24/13 04:14 PM
10/24/13 04:14 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
YOU asked for "correct" and you got some good/accurate replies. There's no grey area ("currently perceived") about it. The way the facyory did it is well known and documented, doing it any other way is simply NOT correct.
Re: 340 exhaust manifold pictres needed - correct overspray [Re: ScottSmith_Harms] #1522421
10/24/13 07:19 PM
10/24/13 07:19 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
That hanging motor turned to this:
Re: 340 exhaust manifold pictres needed - correct overspray [Re: ScottSmith_Harms] #1522422
10/24/13 08:37 PM
10/24/13 08:37 PM
mopar346 Offline OP
mopar346  Offline OP
I undestand, agree, respect and appreciate all the information supplied. I realize most everything known is pretty solid at this point but new information surfaces still today. The orange small block cut off for instance. At one time it was thought that the fender black out was done with a cardboard template covering the engine compartment and sprayed afer the body was pnted, it is now understood that the black was sprayed first. Cars restored to what was thought to be crrect 15-20 years ago are now moched for being incorrect, but that was info available at that time. Not arguing any points above, just tryng to be as correct appearing and durable all at the same time. I am very analytical many times to a fault, but that is something I have to come to grips with.
Re: 340 exhaust manifold pictres needed - correct overspray [Re: mopar346] #1522423
10/24/13 09:22 PM
10/24/13 09:22 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Oh make no mistake, I agree completely on the subject of details that we either have wrong, will be discovered later, or possibly never be discovered due to the passage of time and loss of untouched original reference examples or factory supportive documentation. However, when it comes to the paint coverage on 340 exhaust manifolds that you specifically asked about, you can bank on the current knowledge being accurate, that's an easy one! Respect back at you!
As far as the 71 340 engine color cutoff date, so far all we have to go by are surviving examples, I have yet to see a factory document which details the changeover date, hopefully someday it will surface, but I sort of doubt it ever will. Concerning my post on the subject elsewhere, that was my attempt to share/add to a rather recent discovery, but that discovery didn't really change the (yet unknown exact cutoff date) but rather tossed in a "Never say never" example of a car that received an orange engine way past the blue/orange changeover date simply due to an earlier built engine being installed LONG after it was intended due to some problem with the engine or inventory.
Re: 340 exhaust manifold pictres needed - correct overspray [Re: ScottSmith_Harms] #1522424
10/24/13 10:28 PM
10/24/13 10:28 PM
mopar346 Offline OP
mopar346  Offline OP
I agree the exhaust manifolds are known issues at this point. I have seen what I am talking about and it looks good in my opinion but yes only correct looking until they were cranked and run.
Above I think it was mentions to spray engine paint over the powder/ceramic coating and let it naturally burn off. Has anyone done that and does it leave a stain on the coating were the paint was?
