Gauge mounting question #1521222
10/21/13 11:03 PM
10/21/13 11:03 PM
Akron, Ohio
ProSport Offline OP
ProSport  Offline OP
Akron, Ohio
I would like to make a gauge cluster for my car out of 1/4" thick wood, plastic, or plexiglass, it will be wrapped in carbon fiber vinyl when finished. Should I use a 3 3/8" hole-saw for a 3 3/8" gauge or should I use a smaller hole-saw and file it? The tachometer is 3 3/8" and my other gauges are 2 1/16".
I'm not using metal or aluminum simply because I don't have any tools to cut nice circles in them.
There are companies that make nice housings but they are way out of my price range(photo attached).
Re: Gauge mounting question [Re: ProSport] #1521223
10/21/13 11:23 PM
10/21/13 11:23 PM
Downtown Roebuck Ont
Twostick Online content
Still wishing...
Twostick  Online Content
Still wishing...
A good quality hole saw for metal will give you good results if you would prefer a metal panel. I would mount the panel to some 3/4" plywood as a backing before I drilled the holes so the panel doesn't deflect and distort the holes while drilling. Use the 3 3/8 and 2 1/16. Drill press recommended no matter what material you choose.
Kevin
Re: Gauge mounting question [Re: Twostick] #1521224
10/22/13 12:07 AM
10/22/13 12:07 AM
Akron, Ohio
ProSport Offline OP
ProSport  Offline OP
Akron, Ohio
Thanks, sounds easy enough.
Re: Gauge mounting question [Re: ProSport] #1521225
10/22/13 09:57 AM
10/22/13 09:57 AM
SE Washington
Forest Offline
Forest  Offline
SE Washington
Re: Gauge mounting question [Re: Forest] #1521226
10/22/13 08:36 PM
10/22/13 08:36 PM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
http://www.redlinegaugeworks.com/products.asp
^^^this^^^.
I have used a couple of these and they are GREAT. Perfect fit and the redline guys are super to deal with.
Re: Gauge mounting question [Re: cudadoug] #1521227
10/22/13 10:11 PM
10/22/13 10:11 PM
Akron, Ohio
ProSport Offline OP
ProSport  Offline OP
Akron, Ohio
I just spent 2 days making mine and now you post that lol, those are nice! Pretty affordable and you can arrange the gauges however you want them.
Re: Gauge mounting question [Re: ProSport] #1521228
10/22/13 11:47 PM
10/22/13 11:47 PM
cudadoug Offline
cudadoug  Offline
Ruht roh, Bob!
I see they're still $100. Same as the first one I bought...in 2004!
Re: Gauge mounting question [Re: cudadoug] #1521229
10/23/13 10:13 AM
10/23/13 10:13 AM
Akron, Ohio
ProSport Offline OP
ProSport  Offline OP
Akron, Ohio
Nice, might have to pick one up.
