Re: Launch pictures... tires definitely wrinkled!
[Re: dvw]
#1519063
10/17/13 05:28 PM
10/17/13 05:28 PM
Posts: 2,224 Arlington, Tx.
BJS racing
Arlington, Tx.
The tire actually looks pretty good. If you look at the tread does it appear that there is the same wear on the tire from the outside of the tread to the center?
Back in the swing of things at Painless again! Great to be back!
[Re: gregsdart]
#1519067
10/18/13 01:09 PM
10/18/13 01:09 PM
Posts: 903 Saskatchewan, Canada
cudabin
10.5W-31 M/T tires with tubes,on 12" rims using 10.25psi.
Gears are 4.56's
I always struggle to control the wheelie and if i tighten it up and the track is good, I can run 1.18 to 1.19 sixty foots. however later in the afternoon, it may spin and run a 1.25 sixty and I lose the race...
I bought a power grid to use for next season and I can hit the tires then take out 8 degrees timing after .2 seconds (before the car actually moves) then ramp it back in by 1.8 seconds.
This slowed the car down to a 1.22 sixty foot, but repeated 4 run's in a row!
Next step is to try and ramp the power back in sooner say all in at 1.4 seconds and see what happens!
Cheers,
Arnie
67 Cuda 8.48@ 158.7 mph 1.18 60' 2,600 DA(so far...)
70 Super Bee 440 Six Pack 4-speed. 13.2 @ 104 Stock exhaust/Street tires.
[Re: bentwheel43]
#1519070
10/18/13 09:32 PM
10/18/13 09:32 PM
cudabin
It can run 8.50's in decent air in the 1/4 at 156-157 mph, but Humidity was high this fall...
Cheers,
Arnie
[Re: cudabin]
#1519071
10/19/13 12:00 PM
10/19/13 12:00 PM
Posts: 635 mississippi
bentwheel43
mississippi
AS John Force would say," just kidding".
Section 8 Racing We are nuts about racing.
