Launch pictures... tires definitely wrinkled! #1519060
10/17/13 05:01 PM
10/17/13 05:01 PM
Saskatchewan, Canada
cudabin Offline OP
cudabin  Offline OP
67 Cuda 8.48@ 158.7 mph 1.18 60' 2,600 DA(so far...) 70 Super Bee 440 Six Pack 4-speed. 13.2 @ 104 Stock exhaust/Street tires.
Re: Launch pictures... tires definitely wrinkled! [Re: cudabin] #1519061
10/17/13 05:24 PM
10/17/13 05:24 PM
California
mickm Offline
mickm  Offline
California
don't know enough to offer any meaningful advice, but yup! those tires are biting!
Re: Launch pictures... tires definitely wrinkled! [Re: cudabin] #1519062
10/17/13 05:24 PM
10/17/13 05:24 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
How much tire PSI? You've made good progress since your initial outings.
Doug
Re: Launch pictures... tires definitely wrinkled! [Re: dvw] #1519063
10/17/13 05:28 PM
10/17/13 05:28 PM
Arlington, Tx.
BJS racing Offline
BJS racing  Offline
Arlington, Tx.
The tire actually looks pretty good. If you look at the tread does it appear that there is the same wear on the tire from the outside of the tread to the center?
Back in the swing of things at Painless again! Great to be back!
Re: Launch pictures... tires definitely wrinkled! [Re: BJS racing] #1519064
10/17/13 07:32 PM
10/17/13 07:32 PM
Penna
70satelliteguy Offline
Penna
Somebody done stole your headlights!!!!!!
Mike
Re: Launch pictures... tires definitely wrinkled! [Re: cudabin] #1519065
10/17/13 07:44 PM
10/17/13 07:44 PM
Lehigh Acres, Florida
rickstershemi Offline
Check out these shots:
http://www.pbase.com/nitroimage/image/152875130
http://www.pbase.com/nitroimage/image/152875144
http://www.pbase.com/nitroimage/image/152875552
Seems to be hitting the tires pretty good!
Comments??
Arnie
1st....AWESOME
Don't see a problem....sure you have played with the pressures.....if the 60's are dropping off you're most likely ready for a new set of tires....beats the sidewalls to death
Rickster
Re: Launch pictures... tires definitely wrinkled! [Re: rickstershemi] #1519066
10/17/13 08:55 PM
10/17/13 08:55 PM
gregsdart Offline
gregsdart  Offline
Looking good, Arnie! What size tire and gears?
Re: Launch pictures... tires definitely wrinkled! [Re: gregsdart] #1519067
10/18/13 01:09 PM
10/18/13 01:09 PM
cudabin Offline OP
cudabin  Offline OP
10.5W-31 M/T tires with tubes,on 12" rims using 10.25psi.
Gears are 4.56's
I always struggle to control the wheelie and if i tighten it up and the track is good, I can run 1.18 to 1.19 sixty foots. however later in the afternoon, it may spin and run a 1.25 sixty and I lose the race...
I bought a power grid to use for next season and I can hit the tires then take out 8 degrees timing after .2 seconds (before the car actually moves) then ramp it back in by 1.8 seconds.
This slowed the car down to a 1.22 sixty foot, but repeated 4 run's in a row!
Next step is to try and ramp the power back in sooner say all in at 1.4 seconds and see what happens!
Cheers,
Arnie
Re: Launch pictures... tires definitely wrinkled! [Re: cudabin] #1519068
10/18/13 02:09 PM
10/18/13 02:09 PM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
It sounds like you are on the right track by dialing the power down to limit wheel spin. I would suggest changing the gear set to 4.30 or 4.10 or even a tighter converter, but what do I know? I have never been that fast in my wildest dreams
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: Launch pictures... tires definitely wrinkled! [Re: cudabin] #1519069
10/18/13 05:07 PM
10/18/13 05:07 PM
mississippi
bentwheel43 Offline
bentwheel43  Offline
mississippi
Is this 8.70 dial-in the 1/8 or the 1/4?You are a bad man!!
Section 8 Racing We are nuts about racing.
Re: Launch pictures... tires definitely wrinkled! [Re: bentwheel43] #1519070
10/18/13 09:32 PM
10/18/13 09:32 PM
cudabin Offline OP
cudabin  Offline OP
It can run 8.50's in decent air in the 1/4 at 156-157 mph, but Humidity was high this fall...
Cheers,
Arnie
Re: Launch pictures... tires definitely wrinkled! [Re: cudabin] #1519071
10/19/13 12:00 PM
10/19/13 12:00 PM
mississippi
bentwheel43 Offline
bentwheel43  Offline
mississippi
AS John Force would say," just kidding".
