Re: Installing Key Buzzer
[Re: gregsgscuda]
#1518504
10/16/13 07:27 PM
10/16/13 07:27 PM
Posts: 1,526 North Carolina
cjskotni
North Carolina
Can any one tell me how to remove the steering colom were the blinker handle come out. I have removed the snap ring and it still won't come off. Thanks
You didn't say what year and car but if it's anything like my column in my 73 Charger, you will need to carefully pry the top housing piece off with two flat head screwdrivers.
I actually used two tiny pry bars -- one on each side and slowly worked the piece off the column shaft. Most likely you will chip the paint to be ready.
[Re: 71birdJ68]
#1518506
10/16/13 10:11 PM
10/16/13 10:11 PM
cjskotni
North Carolina
Lets try a different way. Is the buzzer bad? If so, and it's a 71 or newer, the buzzer is not in the steering column. Its in the horn relay. So, exactly what are you talking about?
True. I was assuming this was referring to the buzzer switch and not the buzzer itself.
[Re: gregsgscuda]
#1518508
10/17/13 03:45 PM
10/17/13 03:45 PM
Posts: 434 sweden
cuda-sweden
sweden
buy loan or build the tool to pull it of the shaft,theres a pic of the tool in the fsm,very easy to build.
