Installing Key Buzzer #1518502
10/16/13 06:27 PM
10/16/13 06:27 PM
NJ
gregsgscuda Offline OP
NJ
Can any one tell me how to remove the steering colom were the blinker handle come out. I have removed the snap ring and it still won't come off.
Re: Installing Key Buzzer [Re: gregsgscuda] #1518503
10/16/13 06:56 PM
10/16/13 06:56 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
What does that have to do with a key buzzer? What kind and year of car?
Re: Installing Key Buzzer [Re: gregsgscuda] #1518504
10/16/13 07:27 PM
10/16/13 07:27 PM
North Carolina
cjskotni Offline
cjskotni  Offline
North Carolina
You didn't say what year and car but if it's anything like my column in my 73 Charger, you will need to carefully pry the top housing piece off with two flat head screwdrivers.
I actually used two tiny pry bars -- one on each side and slowly worked the piece off the column shaft. Most likely you will chip the paint to be ready.
Re: Installing Key Buzzer [Re: gregsgscuda] #1518505
10/16/13 09:56 PM
10/16/13 09:56 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Lets try a different way. Is the buzzer bad? If so, and it's a 71 or newer, the buzzer is not in the steering column. Its in the horn relay. So, exactly what are you talking about?
Re: Installing Key Buzzer [Re: 71birdJ68] #1518506
10/16/13 10:11 PM
10/16/13 10:11 PM
North Carolina
cjskotni Offline
cjskotni  Offline
North Carolina
True. I was assuming this was referring to the buzzer switch and not the buzzer itself.
Re: Installing Key Buzzer [Re: cjskotni] #1518507
10/17/13 12:26 AM
10/17/13 12:26 AM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Kinda like pulling teeth isn't it. All I hear is crickets from the OP. I guess me and you could just talk about what buzzers and steering columns have to do with each other.
Re: Installing Key Buzzer [Re: gregsgscuda] #1518508
10/17/13 03:45 PM
10/17/13 03:45 PM
sweden
cuda-sweden Offline
cuda-sweden  Offline
sweden
buy loan or build the tool to pull it of the shaft,theres a pic of the tool in the fsm,very easy to build.
